Hey my mate recently blew up his R33 engine. Noting the basics its a Rb25 block, GTR crank, GTR rods and 92mm pistons. Anyhow when he took the pistons out there was a cutout up the side of the piston and when u look down the cylinder bore from the top where the head would normally sit there is a squirter nozzle there which appears to squirt oil onto the underside of the piston. My question being, is this a standard item on RB engines? We havent seen inside one b4 so wouldnt have a clue. The cutout in the piston is on the same side as the oil squirter like its been cut out to clear the nozzle? Anyone got ideas?
https://www.sau.com.au/forums/topic/36776-oil-squirter-for-piston/
yes as said b4 they are std in most nissan engines due too japan having the knowledge that you cant get enuff lubrication .....
the oil squirters are for bore lubrication on the thrust side due too the high friction point of the bore just too add an increase of less friction ...if you know what i mean ...
i was glad that my engine had them due too my after market rods having no oil squirter through the centre of the rod so the oil squirters will do the work ....
hope i was of help ...
  • 3 weeks later...
The oil squirters are for piston crown cooling. The rod squirters are for bore lubrication. It is interesting that many aftermarket forged rods dont bother with the bore lubrication holes, not even cut outs on the thrust face of the big end, as some other manufacturers do. Argo are one such company I've enquired about this. They said they have never had any failures attributable to no bore lubrication. Obviously the cloud of oil mist in the sump normally must provide adequate lubrication for this, although it then raises the issue as to why OEM manufacturers bother with it.
hehe i do get you mate, but the angle of my oil squirters do not meet the angle too the piston ..... im saying that oil squirters may also be there for a dual perpose too also lubricate the bore as well my squirters are not on a 90 degree angle but about 35 degree there for when the piston is at top dead center it would lubric8 the bore then when piston comes down near bottom dead center they would cool the piston crown...... get me ....
im not in for a debate im just telling you that not all squirters are the same,
im not just a young enthusiest mate im an engineer as well .
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
