Hey guys,
Just want to know if any one notices water leaking inside the cabin, or is it just mine.
Its not exactly leaking but the carpet is damp, where the passengers left foot would be if there was someone sitting there. I looked under and couldn't see any signs of water.
Something to note though, i did recently get my stereo installed and they did replace the battery and ran some cabling around that area.. please refer to the below pic.
Do you think where the cable is run - top left of the picture is where the water may be getting in?
https://www.sau.com.au/forums/topic/367763-car-leaking-water-inside-cabin/
I've run a heap of wires in the same place in my M35 & not had any water get into the car, even when driven in really heavy rain. Having said that, it probably is the cause of the leak, especially if the plastic trim that sits against the windscreen isn't totally flush with the glass. The water could happen to drop straight down the cut they've made in the rubber boot. Nothing some silicon won't fix though :happy: . Good luck.
Mate I've got the EXACT same issue. Water leaks into the cabin and gathers in the left rear passenger's footwell.
I had LPG installed a few months ago and they ran some hoses along the firewall area...I wonder if that's the culprit. The leak only occurs in very heavy rain...
I don't think my cover is missing, but perhaps something there is allowing water to get in? Hmmmmm
if I am looking at that correctly I reckon that the grommet has been cut and that the cable is forming a channel for the water to run inside.
I would take it back to who did the work on it and tell them you think you have a leak and get them to look at it. (looking at it I *think* I know who did the car.)
last one of those I did I put a 4 AWG cable through the end of that grommet neatly and resealed it with black sickflex. you can pull that harness down a fair bit and the grommet end will expand a fair way to allow a cable that size into it.
this should show what I am talking about
that entire harness has been pulled out , stripped and reassembled. it does not leak. compare that to yours :)
yeah the more i look at it the more i'm thinking that's the culprit.
I might pull things apart and give it a dose of sikaflex. If i still have leaks then ill take it to the workshop that did the install which i'm sure will be more then happy to help.
Chris - the fuses sit to the left of the engine bay mounted on a piece of perspex.
Be careful of touching it, then going into shop. They may knock it back.
Also sorry, but where is the fuses? They should be as close to the battery as possible, if you have a short between the battery and "to the left side" of the engine bay, you will be in a world of hurt.
Edited by omp
part of the reason I pointed it out. I can see the factory terminal low right corner but IF that battery moved an inch to the righ then that car is going to go up in flames. sorry but looking at it from my POV thats what I see. those batteries pack a fairly strong punch when shorted..
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
