What date suits you best...
22 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
MENU for U12's
Choice of fish & chips, beef or chicken schnitzel or chicken nuggets with a free soft drink and ice-cream for $8.50.
The numbers are looking excellent..."watch this space Ruby"...we might get close to cracking it :yes:
No matter the numbers we are certainly looking forward to it.
O'Jules & Mark
  • Replies 127
has the meet point been posted yet??? can't remember seeing it on here, or are you sending pm's
..indeed it has but because you are sooo special, here it is again,
SA STAGEA FAMILY FUN CRUISE & LUNCHEON
DATE: Sunday July 17th
Start Location: Le Cornu Car park cnr Anzac Highway & Leader Street Forrestville
(park over near the Anzac Highway & Maple Avenue boundry)
Meet Time: 10.00am
Start Time: 10.30am SHARP
"the OLD peeps"
change of plans slightly. myself + 4 :) hope its no hassle
"Not so sqeezy"....
No number don't matter till the morning of the cruise, when we are ringing through the lunch order
O'Mark & Jules
I'll probably be attending by myself so anyone who wants to jump in with me is more than welcome....... As long as they like oz hip-hop, cause I'll be cranking it!
Hey Shelly, You might have to learn how to reverse park before the next cruise. :nyaanyaa:
+11ty
one of the most common comments that i've heard since the Custom Imports Tv episode,
"bloody stagea drivers, they don't even know how to hard park properly"
lol
Now we are really lookin' forward to the cruise...Brad came over and has
made the Jap radio sing in Aussie....at last we have FM music ! :cheers:
BTW Steve...Brad found the thing wasn't connected to the other thing which stopped the first
thing from working, so he got a new thing, connected it to the....whatever the case it is
now working...TA muchly for trying. :yes:
Now we need to save up some $$ & get the "screen" dancing too.
after today...the seriously OLD fella
Thanks Mark. It was fun maikng a house call.
As for the screen there is about 5 video locks we only got 2. Still have to trick it into reverse, cut the speed sensor and fix the park/neutral switch. If you want to lend me your car one day I reckon ill have it sorted. :thumbsup:
It is a RAIN,HAIL,WIND OR SHINE CRUISE
1. Route sorted...maps are done ! :banana:
2. Kids surprises obtained, sorted & ready (Thanks O'Jules) :merli:
We have a 1hr drive..."BREAK"....followed by another 1hrs drive...."LUNCH"...then a 30min drive "home" :cheers:
All in all....looking like an awesome day, I (O'Mark)will be in Sydney all week leading up to the cruise.
"the OLDS"
Do we want a North meet point for this? It's a fairly central meet point so not necessary...
I was thinking Parafield Bunnings again or North Park/Sefton Park Shopping Centre?
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
