Hey guys,
My car got backed into yesterday and it left chipped a bit of paint on my front bar and I just want to find someone to touch it up.
I've bought some touch up paint before and tried it and it looks dodgy lol.
Am looking for someone that comes to your place and fixes it.
Any recommendations?
Cheers
https://www.sau.com.au/forums/topic/367820-mobile-paint-repairs/
the key to DIY is wetrub more than what you spray (but not too deeply) then spray area required feathering out, then wait to dry, fine wetrub and then polish. Having said that I did have a lot of practice when I worked at Mitsubishi Motors Factory. I know some great guys here in Adelaide but I guess that wont help...
only if you want your car butchered!!!!
stay away from these idiots, they are ex mechanics that know nothing about paint, i wasted $300 years ago only to go to a proper panel shop straight after to fixed properly for another $300.
you have been warned.
OOPS! Haven't heard this bad experience before. Thanks for the heads up though :thumbsup:
"Will it look as good as if I took it to a body shop?"
Touch Up Guys use high quality automotive paints and repair products. Our highly trained professional technicians can produce a repair equal to a panel shop for these cosmetic repairs. Remember, we will only take on a job which we know will meet your expectations.
"What is the guarantee?"
We guarantee to satisfy you… our customer. If for any reason you are not happy with our workmanship please call immediately and we will come back and put it right.
That was from their website, did you try calling the corporate office Jet?
Edited by JamesK
http://www.touchupguys.com.au/melbourne/city.php
He is my brothers brother in law and was previously running his own panel shop for over 10 years. Not sure about the previous users comments but this guy does all the exotic cars in the CBD.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
