yeah, i'll definitely make the hike for good workshops. Racepace on PT is a bit of a trek as i have to train it all the way to Sth Yarra to switch lines to come back down the bay.
Chequered is probably the closest at 25mins, Racepace is about 50mins - Traction Tyres about 40mins - Final Inspection is about 1 hour.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
