Black NISSAN S14 Silvia 200sx MINT Drift/Circuit setup
Nissan S14 Silvia 200sx 1995
POSTING FOR A MATE DON'T PM
EXTERIOR
Aftermarket bodykit “front bar, sideskirts and rear pods recently sprayed”
Smoked rear taillights
Clear side indicators
18x10 +15 black rota gridr wheels (11k with rims, 10k without rims)
Rolled guards
SUSPESNION
Tien HA coilovers
Front and rear Strut tower bars
SMM (simon's modifed knuckle setup) consisting of his shortened knuckles and CNC bolt in spacers
MECHANICAL/ENGINE
Healthy SR20DET VVT engine at 150psi each cylinder
All oils/fluids/spark plugs/airfilter/diff oil/gearbox oil changed
S15 ballbearing turbo
3” exhaust one piece
Stealth black front mount intercooler FMIC “no blow off valve”
DRIVETRAIN
4.3:1 differential ratio soon to be 4.9:1
1.5 clutch type way LSD Kazz
Exeedy heavy duty clutch
ME
Hi everyone...
To cut a long story short, I’m a mechanic who has been waiting to get my licence BACK since forever!
I have brought this car and spent the last 6 months on getting it exactly the way I want head to toe, perfect to the last bolt and for Drift/Circuit/Daily! Vehicle was dead stock when brought, most parts are either brand new or freshly purchased with less than one kilometer of use. Went to the RTA recently turns out I have to go back on my P’s! I can’t drive a turbo. Ive brought an n/a 180sx to pig around with so this car needs to go!
Vehicle is clear on REVS.
No money owning and no accident history!
“I would know worked on the car head to toe!”
PRICE $11,000
OR $10,000 without wheels
COMES WITH 12 MONTHS REGO
NOTE - I've got other wheels to put on if you decide to take it without the rota grid r's
Located in Wollongong “one hour from Sydney NSW”
Can help organize a tow truck
Can help organize to send interstate
I’m a decent guy keen for a chat just please no time wasters!
Chris – 0421 816 651
any cop trouble for rear fitment?
had a fair few cops drive past
because the car is so raised they dont really look twice
would b a diffrent story if i dumped it i think
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
