Black NISSAN S14 Silvia 200sx MINT Drift/Circuit setup
Nissan S14 Silvia 200sx 1995
POSTING FOR A MATE DON'T PM
EXTERIOR
Aftermarket bodykit “front bar, sideskirts and rear pods recently sprayed”
Smoked rear taillights
Clear side indicators
18x10 +15 black rota gridr wheels (11k with rims, 10k without rims)
Rolled guards
SUSPESNION
Tien HA coilovers
Front and rear Strut tower bars
SMM (simon's modifed knuckle setup) consisting of his shortened knuckles and CNC bolt in spacers
MECHANICAL/ENGINE
Healthy SR20DET VVT engine at 150psi each cylinder
All oils/fluids/spark plugs/airfilter/diff oil/gearbox oil changed
S15 ballbearing turbo
3” exhaust one piece
Stealth black front mount intercooler FMIC “no blow off valve”
DRIVETRAIN
4.3:1 differential ratio soon to be 4.9:1
1.5 clutch type way LSD Kazz
Exeedy heavy duty clutch
ME
Hi everyone...
To cut a long story short, I’m a mechanic who has been waiting to get my licence BACK since forever!
I have brought this car and spent the last 6 months on getting it exactly the way I want head to toe, perfect to the last bolt and for Drift/Circuit/Daily! Vehicle was dead stock when brought, most parts are either brand new or freshly purchased with less than one kilometer of use. Went to the RTA recently turns out I have to go back on my P’s! I can’t drive a turbo. Ive brought an n/a 180sx to pig around with so this car needs to go!
Vehicle is clear on REVS.
No money owning and no accident history!
“I would know worked on the car head to toe!”
PRICE $11,000
OR $10,000 without wheels
COMES WITH 12 MONTHS REGO
NOTE - I've got other wheels to put on if you decide to take it without the rota grid r's
Located in Wollongong “one hour from Sydney NSW”
Can help organize a tow truck
Can help organize to send interstate
I’m a decent guy keen for a chat just please no time wasters!
Chris – 0421 816 651
any cop trouble for rear fitment?
had a fair few cops drive past
because the car is so raised they dont really look twice
would b a diffrent story if i dumped it i think
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
