Whiteline Sway bars Front & Rear for Nissan 350z & V35
What is up for sale here is the Whiteline front and rear sway bars BRAND NEW NEVER USED OR TRIED ON for your Nissan 350z or V35 Skyline. The fitting of bigger Whiteline swaybars is still the best dollar for dollar handling improvement you can make. Cornering loads are spread more evenly across the tyres delivering more grip and frankly, that's what it's all about. You also get improved tyre wear as your tyres stay flatter and more upright. Comfort improves because your car sits flatter through bends meaning less movement inside the vehicle. Whiteline swaybars are manufactured using the finest grade spring steel. They are powder coated and supplied with high performance polyurethane mounting bushes in a DIY kit form, ready to simply bolt on.
What you will get
Front Sway Bar - BNF33Z <br style="color: rgb(255, 0, 16);">Rear Sway Bar - BNR30Z
Includes all Bushings - easy bolt on DIY no extra parts neccasery
Here is a link to their webpage for further information:
v35 - 2003 to 2008 models
http://www.whiteline...cle=G35+2003-08
350z - 2003 to 2009 models
http://www.whiteline...STER+10%2F03-09
I am selling these for $520 for both. That is a saving of $115 from the original pricing that can be seen from the above link
Front Sway Bar - BNF33Z - $335 (My price $270)
Rear Sway Bar - BNR30Z - $299 (My price $250)
I have these posted elsewhere and may be open to selling them seperatly for a higher individual price.
These are based in Sydney. I dont mind meeting people halfway in Sydney eg if your from Gosford/wollongong or Blue mountains I am open to meeting for sale. Pay via Cash
If you are out of reach and need Postage please contact me for prices.
Here is a link to my ebay auction - http://www.ebay.com.au/itm/Whiteline-Sway-Bars-Front-Rear-Nissan-350z-V35-/190544783864?pt=AU_Car_Parts_Accessories&hash=item2c5d5aa9f8
Edited by jawrgy
https://www.sau.com.au/forums/topic/367839-swaybars-v35-front-rear/
I've just fitted these to an M35 Stagea and the difference is incredible. Very worthwhile improvement for any V35 or M35.
Good luck with the sale! :thumbsup:
  • 1 month later...
Yes they will.
Cheers Dale.
I'm a little confused,
the maker of Godspeed sways tells me that they are only for coupe, but yet the whiteline ones could fit both 2drs and 4drs?
so far 22 views and no reply yet
Edited by nissan rules
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
