http://www.motorauthority.com/news/1061595_2012-bmw-m5-leaked
Though it isn’t set to make its official world debut until this September’s 2011 Frankfurt Auto Show, the new 2012 BMW M5 has hit the Internet by way of a leaked report and is already striking terror in the hearts of AMG and RS fans all around the globe. That’s because the latest generation F10 bruiser comes packing a twin-turbocharged 4.4-liter V-8 developing 552 horsepower and 510 pound-feet of torque.
Purists may miss the high-rev V-10 of the E60 M5, but the new force-fed V-8 should prove to be much more usable. Its peak torque, yes all 510 pound-feet of twist, arrives at just 1,500 rpm.
This is directly reflected in performance, with the 2012 BMW M5 accelerating from 0-62 mph in just 4.4 seconds versus the previous car’s 4.7 second time. The 0-124 mph run, meanwhile, will take you 13 seconds.
Note that these acceleration figures are with a seven-speed M-DCT dual clutch transmission. A conventional six-speed manual is almost certain to be offered in the U.S. market given the prototypes spotted recently.
Top speed will remain at an electronically limited 155 mph, however an M-Drivers-Package is said to be available, which will lift top speed to a reported 189 mph.
Other details mentioned in the leaked report include an Active M-Differential with torque vectoring between the rear wheels, 20-inch light alloy wheels and a sub-8 minute Nurburgring lap time.
While the car’s official world debut isn’t set to occur until September, the new 2012 BMW M5 will reportedly make an appearance at the M Festival at the Nurburgring 24 Hours endurance race in Germany on June 23.
https://www.sau.com.au/forums/topic/367841-2012-bmw-m5-revealed/
Looks great, A bit more understated like the original M5 I think.
I reckon it will have been hard to get the twin turbo motor sounding as good as the old V10 at high revs or the E39 with the NA V8. Like the Golf R32 vs the new Golf R.
Another link: Motor Report
2012_bmw_m5_official_europe_01-4df93ebe534cf-m,3A610x450.jpg.pagespeed.ce.2HVnk5bNkL.jpg
2012_bmw_m5_official_europe_02-4df93eca7f18f-m,3A610x450.jpg.pagespeed.ce.N9tqUbTilS.jpg
I think it would've been good to see some clear indicator lenses at the rear like some of the earlier Ms.
2012_bmw_m5_official_europe_07-4df93ed189de2-m,3A610x450.jpg.pagespeed.ce.NaVgz62iWv.jpg
And I think in recent news it was hinted at that the new 1 Series is likely to be hatch only (possibly including a GT variant) with the coupe / vert going to "2 Series" designation; the 1 Series will have four-pots while the 2 Series could have sixes. Good to hear.
Agreed, I'd love an E39 M5 and they're within striking distance budget-wise to acquire... Not sure about maintenance though as they are a complicated beast (not that the GTR isn't, but when you have self levelling dampers, about 6 oxygen /lambda sensors, etc there are many things that could fail)
The other "problem" is that because they are such a comfy car, many have done high miles. Looking for an E39 M5, it's rare that a well looked after one comes up with less than, say, 120,000km on it...
Yep. Also twin scrolled turbos, DFSI and short intercooler piping and exhaust manifolds inside the valley allows them to run higher compression meaning the turbos are on song from the get go. Really a fascinating engine.
Not sure if its the exact same spec but the S63 engine uses exhaust pulses from each bank through the twin scroll turbos
http://www.bimmerboost.com/content.php?1157-BMW-twin-turbo-V8-analysis-Power-potential-tuning-performance-and-architecture-of-the-N63-and-S63-motors
Looks ok.
It look more like stretched and buffed version of current M3 sedan.
Yep very true and this I believe is mainly due to the fact the 2012 M3 comes out only as a coupe (no more sedan). So if you want a high performance M saloon, the M5 is the only option. Having said this, it has not been official to my understanding.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
