I continue to have a good run with my one, but that's probably as it rarely gets driven any more, and hardly at all to likely defect locations
Mind you, every time I have been spotted by a cop I have been pulled over.
your one I can get sorted legally I bet. needs a height adjustment though.
as for defects - give someone time or a reason and they will find a way to nail you.
https://www.sau.com.au/forums/topic/367856-defected/page/2/#findComment-5871217
just over 12 months ago my mate was pulled up whilst at a dyno comp by on the coast by brissy police, in his neat series 8 rx7 RZ edition, now these special edition ones come with 17" BBS alloys and fixed back red recaro carbon fibre buckets standard.
he had on a FRP bonnet which is fair enough to defect for. But the cop proceeded to fine him for the seats, although these seats are standard factory items, and the car is a 2 seater edition anyway. I was trying to explain this to the cop, but he was arrogant, and threatened to arrest me if i didnt go away. so i did, fuming at his attitude towards the situation, as he didnt care he was writing tickets to meet his quota anyway, being basically factory standard with teins and full exhaust. this STTF guy was a joke.
But what gets me is they can write a tickets willy nilly and you dont get a chance to prove them wrong. and they dont get any recourse for your wasted time and effort going thru the bullcrap to prove them wrong, so they dont care. its a joke.
https://www.sau.com.au/forums/topic/367856-defected/page/2/#findComment-5878153
There should be some sort of procedure whereby if officers are continually having their tickets or charges overturned it should give some sort of avenue of recourse either internally from the police or for the public to exploit.
make it reasonable.
This way I can guarantee you that a police officer will never again issue a bullshit ticket.
https://www.sau.com.au/forums/topic/367856-defected/page/2/#findComment-5878687
I got defected a while ago and that was full of BS. The police don't know what they are looking for and just ticket you for anything that they feel like. I was defected for having a turbo installed on my GTST? When I explained to them that it comes standard with a turbo on it he said no you installed one. We will never win your only chance is to fight it in court and win and then hopefully if there is enough charges overturned in court then maybe they'll look at the way the system works.
BAHAHAHAHAHAHAHA
yeah right
Oh and when I had to clear my defect I didn't need a RWC. I just got put over the pits with a quick inspection then when it passed they cleared my defect off the vehicle using their computer system. It took approx 20 mins and I was in and out.
Edited by skins
https://www.sau.com.au/forums/topic/367856-defected/page/2/#findComment-5879600
pretty sure the old de-register / re-register trick no longer works as the defect goes against the vehicle's VIN number and not the rego like it use to
I de-registered mine years ago and about a year and a half later I had a visit from the local police looking for the car. They wanted to know where it was and if the defects had been cleared etc.
https://www.sau.com.au/forums/topic/367856-defected/page/2/#findComment-5879739
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
