Tony Quinn has bought the Australia GT series.
http://www.speedcafe.com/2011/06/15/australian-gt-sell-management-rights/
Good time to start a Aussie GT thread.
with new cars due through out 2011 and at the start of 2012.
At this stage there is:
3 x Ferrari 458 GT3
1 Nissan GT-R GT3
Rumoured:
1 x McLaren Mp412C GT3
With the Audi, Merc SLS, Lambos, Porsches, Moslers and Astons 2012 is starting to build up
https://www.sau.com.au/forums/topic/367870-australian-gt/
  • Replies 83
Will Tony try and get some decent races happening as its own series? Or just play 2nd fiddle and do 10/12 lap races here and there?
I and many many others would love to see this take off and get air time with propper length races
https://www.sau.com.au/forums/topic/367870-australian-gt/#findComment-5867392
So far this year there have been 1 hour races at each round (EC was 2 X 1 hour)
The Clipsal night race was a great event, on the friday night (at the pub) there was already some deals being made as Tony C from V8 land expressed interest after seeing the race under lights for the 2012 event.
https://www.sau.com.au/forums/topic/367870-australian-gt/#findComment-5867405
Ah cool...havent really followed it this year
But not Tony C please
unless you want the GT cars to be running 4 cyl hyandai motors on LPG and having to have the same body mounted on a big go kart chassis
Sorry i meant Tony C, was interested in taking the later race for the Taxi's.
I know there was talk for 2x 1 hour evening races for the GT's at the clipsal next year (would be the premier national GT race) but that was after a few pints so imaginations could have been running.
:cheers:
https://www.sau.com.au/forums/topic/367870-australian-gt/#findComment-5867443
mmmm love Australian GT.
Awesome cars that unfortunately get smashed up alot possibly due to money>talent (Melbourne 2010 anyone?)
The racing at Eastern Creek this year was suprisingly close - best GT race I've seen in a while. Anyway, here's some Aus. GT porn for you all... zomg SLS!
https://www.sau.com.au/forums/topic/367870-australian-gt/#findComment-5867479
In fairness the saturday GP crash was a mechanical issue on the aston which unfortunately went into "limp home mode" just as the green flag waved. Sunday's was absolutely STUPID and resulted in the GT's not getting the place back this year, F1 corp had enough over the last few years with 75% of the races done completely under safety car and or red flagged.
Racing this year has been close.
and I am biased but yes the SLS is AWESOME!!
https://www.sau.com.au/forums/topic/367870-australian-gt/#findComment-5867508
nice one. at least quinny is a big racing nut and should bring things forward. :)
his R35 targa car at $95K is pretty good too considering it's an aus spec car with road rego. could easily turn it back into a road car and flip it for a profit. or just do the smart thing and race the wheels off it.
https://www.sau.com.au/forums/topic/367870-australian-gt/#findComment-5868333
Not sure on that! Haven't seen too many caged Targa cars that could be "easily" returned to a street car!
But anyways - I hope TQ can get the series up and going better and stronger. Just hope his personal disagreements with CAMS aren't going to get in the way of that happening though.
https://www.sau.com.au/forums/topic/367870-australian-gt/#findComment-5868429
  • 3 weeks later...
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again馃様 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
