Yeah the Japanese prices are complete BS, I've been working with my factory to make 'Nismo-esque' R34 brake light inserts after the amount of people preffered them instead of our unique style.....live and learn!
great reverse lights, super bright :) ...also very interested in the r34 brake lights, how long untill u have a price on these?
Nice work charles, looks really nice... will be a pain when the little bulbs start busting 1 at a time lol
Hey dan, whats the website for all your stuff? I remember you had some pretty nice goodies for the R33's a few years back. Would love to see your 'range' of 'stuff' now - Except the 33 is out the garage and a 34 is in.
Would you believe it, no website! But have lots of things on hand for the R33 at the moment, Dash, A/C, map lights, centre light, number plate bulbs, drop-in bulbs for the brakes and reverse lights (though actually works out a bit costly as that's 6 awesome bulbs for the R33 rear end)
Just PM if you've got specifics in mind
Charles,
What did you use to re-seal the Reverse light cover/housing when you put it back together?
Nothing lol.
Because even if the glue gets cold when you put it back together, it still bond like crazy, so by the time to push the 2 parts back together, you are going to be able to pull them apart without heating it again.
And FYI, after I took them apart, I tried to cut out as much glue as I can lol, coz it just gets too messy with the glue everywhere.
After many high pressure rinse and many days of rain, not one drop of water in the lights :)
  • 4 months later...
These look great Charles!!
Any chance you could send me PM me with the details so mine can look as awesome as yours?? :cheers:
What would you like to know? :P
Charles, or anyone reading, any idea how this is accomplished?
Apparently, this person has his fog light wired to his headlights (RED). That changes (WHITE) when in reserve gear.
I wouldn't have a clue lol. But I think in the GTR, there's a rear fog switch on the indicator stalk, and they somehow hooked up the white LEDs to reverse light for power, so when the car is in reverse, the white lights comes on, and when they are off, the right one remains red. Not sure how they constructed the right side light. Whether it's 2 panels, 1 white 1 red or 1 panel that can change between white and red.
I know for sure that I won't have LED rear fog lights....
Did one for a GTR few weeks ago, they blinded me when I was testing them... So imagine for the people driving behind you lol.
...well I'm just wondering if you could take out the trial n' error part in helping me out with what resistors you used, I have found similar LED boards but not sure on the dimensions of the ones you used... Any info you're willing to share would be greatly appreciated Charles :yes:
  • 10 months later...
Hey guys,
Since some of you liked my front lip DIY, I thought I'll post up another DIY that I did tonight. This time is my rear reverse light, spent about 3 hours on this.
Since I changed my right reverse light for a fog light, I've notice I can barely see when I'm reversing during night time, as I'm only left with one light, so I thought I'd brighten things up with 96 LEDs :D
Luckily, I found myself a pair of 2nd hand reverse lights to stuff around with.
Here's some pics of the process:
I opened up the reverse light housing
Connected two 48 LED panels together
Connected the T10 end to the plug
Made a surround/backing for the LED panels (yes it's a half dodgy job lol)
Because I wanted white light, not yellow light, I thought I'd try and clean the lens a bit lol.
Started to wet sand it with 1200
Finished it off with 2000 and a polish and BAM! The crap is off.
Put the brand new looking lens back on
Due to the time now, I haven't had a chance to put it back onto the car. But I don't think I'll convert my rear fog light to LED, as it's definitely gonna blind people behind me lol.
Hey mate was just wondering how you got the lense off the lights, just purchased the lights and currently waiting on the LED panels to arrive :) and info would be much appreciated! Cheers
75 degrees c in the oven for 15 minutes, swift hands with a flate bladed screw driver to pop the bkac clips (they will be soft and very easy to move), pry the lens in a perfectly vertical position about 20cm....alow the glue to cool, then carry on, prevents any sticking to the inside of the lens and breaking out the shellite to clean the crap off. If the glue starts to cool too quickly, stop what you're doing and put them back in the oven for round two. Have your calm pants on that day.
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
