Hey guys,
I just found out that 2 of my headlight brackets have been snapped during an accident. It was a very clean break.
So I'm just wondering if anyone knows any good plastic welder around Melbourne?
And if I do plastic weld it, would I see the weld marks? Or are they good enough to make it invisible? :D
Cheers
https://www.sau.com.au/forums/topic/367926-plastic-welder-in-se-melbourne/
Is the attached break in the pics fixable? Wouldnt mind fixing this series 2 headlight but if it cant be done/to expensive then will not bother.
Yea bud that's fixable it shouldn't be to much but don't quote me, I had worse fairing damage to my motorbike, they welded it, sanded it, and painted it, good as new, since its on the inside they will probably only need to weld it back together as long as you dont mind it looking a little funny
EDIT: Also try pretty much any motorcycle repair shop it's pretty much a required skill for them since when you crash your going to break plastics also they might be a little be more well equipped for a smaller job since its not like a crack in your front bar or whatnot
Edited by JamesK
Thanks for the reply mate, actually replaced my headlight so this is a spare. Just deciding if it's worth fixing and flogging off... I'll try some bike repair places and see what sort of $ to fix then work out if it's feasible. Cheers.
