Make: Nissan
Model: R33 GTS-T
Transmission: Manual
Colour: Black
Currently registered? Yes till 18/8/11
Price: $9,800 (or will swap for a car of lesser value + money my way)
Contact: 0402 902 759
Comments / Modifications:
Currently only running standard turbo with standard boost which has been great for a daily driver. Was previously making 252rwkw but has since been return closer to stock which still provides some good power combined with the Bilstein Suspension makes a very good overall package.
Compression tested
1:180
2:180
3:180
4:176
5:180
6:180
ENGINE
- Full engine rebuild with CP forged pistons + rings, fully balanced with all new bearings and gaskets.(Comes with $10,000 Worth of receipts for engine + clutch)
- Rebuilt head
- Exedy Super Single Brass button Clutch
- Bosch 040 Fuel Pump
- Turbosmart boost controller
- Front Mount Intercooler
- 3A Racing pod filter
- 3" front and dump into a 3" cat and 3" cat back with mid muffler and oval muffler on rear.
SUSPENSION
- Bilstein shocks with Whiteline Springs (Height Adjustable)
- Endless hicas lock bar (Engineered with paperwork from Doug Potts & and passed through Regency)
- Replaced Diff with 4.11 Ratio
INTERIOR
- Re-trimmed Leather Steering wheel, Perfect condition
- Silver Dash Surround
EXTERIOR
- S2 rear wing
- Standard S1 M Spec Front Bumper (average condition)
- Jun rear bar ext
- DNA Wheels. 17x9 +30 all round
- GTR type grill
- nismo indicators
Edited by Trackwork
https://www.sau.com.au/forums/topic/367942-r33-forged-rebuilt-motor/
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
