Selling my GT3076R, its a 56T 700382-12 turbo which is only a few months old. Comes with NO rear housing so put your own .6 or .8 and run either external or internal gate. FWIW i was running .63 ex gated and making over 300 rwkw with this turbo
price is $900 FIRM... BYO rear housing.
postage $20 anywhere in AUST.
PM me if keen.
IN SA
Yeah don't lower the price simon, it is just a matter of someone actually wanting on and having the money for it. Perhaps spam the garret thread, or put a link in your sig to it?
Bump
Damn Cheap!!!:yes:
Specs can be found here: Garrett GT3076R 700382-5012
Anyone after a rear housing for this I will help you out price wise, mention Simon's add in an email to me at work
  • 2 months later...
  • 1 month later...
no turbo is sold.
as for differences.. well the 3037 is what garret sold to HKS for their HKS range. its the same core.. just the housings were different. but a garret 3037 is a 3076 really.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
