Set of Factory Enkei 370z 18 inch rims and tyres removed from a 2010 model,
the rims are in very good condition, made by Enkei for Nissan.
Check below I have taken pics of each rim close up
Stud Pattern: 5x114.3
Fronts measure: 18x8 +43 OFFSET
Rears measure: 18x9 +15 OFFSET
they are wrapped in Yokohoma Advan sport tyers
Tyres: fronts 225/50/18 there both about %85 tread left
rears 245/45/18 96W - one tyre is above the wear indicator with some tread left and the other tyre is pretty much baldy.
Great upgrade for your 350z or for other 5x114.3 stud patterned Nissan's such as Skylines, 200sx, Silvia's but may need to run spacers to clear the front brakes.
$1300 for the full set as pictured
Nissan ask about that much for just 1 rim
call/ text 0422756270
Pick up Western suburbs Melbourne
Can send with courier Australia wide at buyers cost, I know of a cheap courier that i can get a quote with.
Cheers
Edited by G4orce
This is how they look on a s14a, Spacers where used on the front wheels, but the rears no spacers.
These wheels will look crazy on 32s 33s or 34s
The rears have a tough offset for a stock wheel. +15.
FINAL PRICE DROP $1250 THESE ARE AN ABSOLUTE BARGAIN
Edited by G4orce
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
