Hey everyone
I would like to let everyone know about my unfortunate dealings with a Ryan Lowe aka tranf4m.
on May 17Th i received payment for a turbo i was selling which came off my r32 gtr in perfect working order.
May 18Th - i mailed the turbo from Brisbane Queensland to Roasedale Victoria.
May 20th - turbo arrived to this Ryan Lowe
May 24th - i receive a txt msg about how the turbo is "broken" i queried it and received a pic of a oil line with a crack in it. I was also told the turbo would not fit his standard r32gtr. after it being taken off my stock 32 i found it hard to believe.
May 24Th - I took his word for it and sent the money back that afternoon(both with the same bank so the transfer was instant)
May 26Th - was told it was posted at 9am
June 4Th - queried the postage of the turbo back to me as it has been 9 days which is ample time for it to get from Victoria to Queensland even if someone had to use a push bike to get it here. was told it was posted last Tuesday which equates to the 30th still 4 days later then i was told first time it was mailed.
June 11Th - still no turbo(gave him another week before contacting again just in case he posted it on the 5Th)
no reply back
June 13Th - still no turbo
no reply
June 15Th - still no turbo
no reply
I have called him 6 times and left a message every time. i have not made any threats or questioned the reasoning behind the mystery turbo not fitting or the random crack that appeared in the oil line. i sent it and he didn't want it so i sent the money back in good will with the thought of getting the turbo back.
He will not return my calls so he is being difficult or he has died with his phone on charge because it rings out before going to the msg bank.
If you know this ryan lowe aka tranf4m tell him i want my turbo back.
I would not recommend you buy anything or sell anything to this bloke as you can all see a simple good deed doesn't always go in your favor. If you are ryan lowe and you are reading this i can guarantee karma will get the better of you my friend
Edited by Destero
https://www.sau.com.au/forums/topic/367999-tranf4m/
  • Replies 98
1st rule of issuing refunds as a business: no refund until the product is in your cold dead hands. Treat everyone as a potential criminal, for everyone has the potential to be one. This can and should extend to private selling. Unfortunately you had to learn this the hard way :(
https://www.sau.com.au/forums/topic/367999-tranf4m/#findComment-5869392
as above,
im a financial banking ombudsman. not advice, but what i would do
call my bank and lodge a dispute on the funds as "un received goods"
They may decline the matter due to authorising the transfer through internet banking.
If they decline it, make an ombudsman threat. as it will cost the bank over $680 if you simply lodge one.
i know it suck that they may get away with it, but doesnt mean you should be down the deal.
https://www.sau.com.au/forums/topic/367999-tranf4m/#findComment-5869666
x 10000000000
I used to deal frequently on OCAU and had a few scammers try this on me. I always tell them - no item, no refund....
https://www.sau.com.au/forums/topic/367999-tranf4m/#findComment-5870592
Yeh you live and learn. It wasn't much but it was the principle that there are some bad people about so let this be a lesson to other legitimate skyline owners don't trust anyone.
i have contacted the bank and was lucky enough to get askyline enthusiest on the other end and raised a dispute, he has 30 days to reply :)
https://www.sau.com.au/forums/topic/367999-tranf4m/#findComment-5870826
what they do is they send three requests to the other bank to return the funds - it sucks that its at the discretion of the party who has to provide the goods
if they say no it gets rejected and he'll have to escalate it.. thats where the ombudsman threat will helpthumbsup.gif
https://www.sau.com.au/forums/topic/367999-tranf4m/#findComment-5871154
as above,
Wish I knew this a long time ago :(
https://www.sau.com.au/forums/topic/367999-tranf4m/#findComment-5871589
Hey fellas just a update of the situation
17th june - called bank and lodged a dispute
17th june - told ryan lowe i have lodged a dispute with the bank
22nd june - still havent heard anything from this guy.
He has loged onto sau and changed his preferences to stop showing his last activity. = proves he hasent drove his car off a cliff on the way to post my turbo back.
https://www.sau.com.au/forums/topic/367999-tranf4m/#findComment-5877151
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
