  • Replies 98
no worrier here ... just heard about how dodgy this site was to buy parts from and 1st time got something off here what do ya know dodgy POS i got called a turbo,and the last time ill buy from the dodgy wog spec site .... this guy got what was coming to him selling ppl dodgy shit like he did it was nothing like i had asked for and yet he still sold it to me, i sent his shit back to him so im not the dodgy one on this ,he is ... you guys are the lame one's talking shit not me ... i got something dodgy sold to me so i gave him a lesson , sell ppl what they pay you good cash for or dont get ya shit back rite away
https://www.sau.com.au/forums/topic/367999-tranf4m/page/3/#findComment-6028726
ns.com is over that way --------------->
https://www.sau.com.au/forums/topic/367999-tranf4m/page/3/#findComment-6028774
you from melbourne? sure you dont live in taylor's lakes?
https://www.sau.com.au/forums/topic/367999-tranf4m/page/3/#findComment-6028777
^ this. Me fail English? That's unpossible!
You don't 'teach people a lesson' when they refund you immediately, Asshole. He's been good about it regardless of if it was as described or not. You're the cun.t here....
https://www.sau.com.au/forums/topic/367999-tranf4m/page/3/#findComment-6029115
now ladies.... listen up.......
THIS IS WHAT YOUR KIDS WILL BE LIKE IF YOU DRINK THE BONG WATER AFTER EACH SESSION!!!!!
seriously is the tranny even trying to spell right? He clearly has been going to a school in st albans or is still there, 10 posts and already calling the site shit. Your a credit to 15 year old turds everywhere you need a beatdown :domokun:
Where do I pay for my subscription? If it's shit I will be asking for my money back then hols on to the thread for ever! Muuuuuuuuuuuuhahahahhahahaaaaaa
https://www.sau.com.au/forums/topic/367999-tranf4m/page/3/#findComment-6029457
c'mon man, hub dooy lop centro? lape dun cill a dingos baby. i got called a tworboe sul belook jijk deen lamsen.
tthats my thort eneeway
https://www.sau.com.au/forums/topic/367999-tranf4m/page/3/#findComment-6029829
I'll be damn surprised if he ever went to school at all....
https://www.sau.com.au/forums/topic/367999-tranf4m/page/3/#findComment-6030019
Its people like you that make me glad there are still abortion clinics around.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/3/#findComment-6032325
its guys like you that makes the skylines rep so bad and dodgy and go a head wanna be tough guys talking shgit over the net
Edited by tranf4m
https://www.sau.com.au/forums/topic/367999-tranf4m/page/3/#findComment-6032397
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
