bud you contacted me on my want to buy post
Im guessing the reason you took so long to send the money and send the turbo back was your memory is bad... It all started with you so stop trying to make out it was my fault!!!
Sent 16 May 2011 - 07:04 PM
hey mate just wonering if youd sell the good turbo for $150 to victoria
The reason your getting flamed is quite simple... Your a idiot its not because you can't spell its because you are a scammer.
The whole thing was because you kept the turbo and would not respond in a reasonable time frame. If you think 4 months is reasonable IM sorry ill take back everything. You received my turbo which was in perfect working order that was taken off my skyline. You then said it would not fit because it was not standard, you then said your mechanic said it would not fit which to me sounds like both you don't know what you are talking about and when that failed you claimed there was a oil leak. All this time I did not argue with you even though the "not fitting" thing was a total load of bullshit, you then said it had a crack in the oil line and you were not happy with it. You received a refund within 5 hours with no complaining and with several apologies for the inconvenience in the mean time. You were the reason this went down the drain and ended up viral on the internet. Not because of me it was because of you I did everything on my end to ensure it went smoothly, If I sent it faulty do you really think I would agree and send the money back so quick?!?
In the end your reputation as a skyline owner has ended in tatters with no one on sau ever going to do business with you again and infact everyone here has actually got a bit of laughter out of it with your stupid non grammered comments. On receiving the turbo back its clear you did not look after it and in my professional opinion as a refrigeration mechanic who deals with welding, holes and abrasions on refrigeration piping the hole in the oil line was clearly created by bad handling probably from being tampered with in a attempt to keep it claiming it was faulty before realizing your dealings with me have ended up on the internet.
At the end of the day you have lost and I can guarantee karma will get the better of you in one way or another for the way you have treated me.
Thank you for wasting my and everyone elses time and i thank everyone on sau for your ongoing support. RYAN LOWE if you do continue to dig yourself a hole i am more then happy to provide chat logs and pics from both sau and my phone for you to use as a shovel.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6037582
  • Replies 98
Are you even sure its YOUR turbo he sent back to you? Wouldn't be surprised with this douchelord if he still has your turbo and sent you back his dodgy one.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6037597
I said a hip, hop a hippy a hippy to the hip hip hop you dont stop a rockin to the bang bang boogy said up jump the boogy to the riddim of the boogity beat.
loookseei eyes kan tork lyke tranzgender tu
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6037749
couldnt give to f**ks what ya do.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6040959
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
    • Is the jack stand system tied into the cage somehow? Upgrades look goooood 😍
    • Big updates, tons of work and $$$
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
