  • 2 months later...
  • Replies 98
hey buddy letting you know im not a scammer i asked for a standed r32 GTR turbo that was ingood working order and has no turbo play and what did i get , i got an r32 gtr turbo that and been high flowed by atleast 5 mill so clearly not standered dick head and it had a f**k oil line , huge spilt in it whitch means the turbo had been running with no oil at some point and it needed a rebuild , so clearly not in good working condition , so i thought f**k you , you can wait to get you dodgy as f**k turbo back , ohw and your POS TURBO SHOULD BE AT YOUR DOOR STEP BY NOW SENT IT TO YA LAST WEEK
Edited by tranf4m
https://www.sau.com.au/forums/topic/367999-tranf4m/page/2/#findComment-6025248
Biggest douchebag holy shit, somebody ban his IP so he can't rip anyone else off on these forums. Strangely enough I make it a rule not to deal with people who A) Can't type for shit and B) Use their own fonts, colours and sizes instead of the standard.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/2/#findComment-6025712
look at it how you want cant do shit i sent peace shit turbo back to him,i hope he resel the heap of shit to one of you f**k heads ... if he had of sold me what i wanted in the 1st place whitch he SHOULD OF COCK SUCKERS wouldnt of had this issue . think about it
https://www.sau.com.au/forums/topic/367999-tranf4m/page/2/#findComment-6026780
Haaaaaaaaaahahahahaa you're a f**kin douchelord.
That is all.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/2/#findComment-6026880
f**ken oath. Some people are just f**ked. I tried to buy a turbo from a guy on here several months back and he simply just wouldn't post it. He kept asking me over and over if I had the money. f**ken dur, would I go shopping with no money? But then some people on here are good as gold. Like a young fella called Don (skyzthalimit) that sorted me out with a fuel pump, a z32 afm and a profec A boost controller. The pump and the z32 are still going strong and the boost controller was rooted. I called him up and he said "No worries man just come down and I'll refund your money". And he did. If I had to fly somewhere to get my shit back it would be a motec tune with anti-lag, traction control, flatshifting and individual cylinder correction. And I would run it on the dyno till it popped.
Subscription in the mail.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/2/#findComment-6027333
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
