  • Replies 98
Hey all,
Latest update, the dispute with the bank to have my money refunded was successful and my turbo arived on friday the 23rd of september(4 months later) . The turbo came back a little worst for ware with mold growth, rusted and oily but i am grateful to have it back.
I have also been left some negative feedback for my troubles reuining my 100% rating record :( "wanted working r32 gtr turbo and was every but that , dodgyBuyer: tranf4m (-1) - 23 Sep 2011 - 12:43"
Thanks for all the support i have recieved and be wary of anyone selling or buying skyline parts out of "Roasedale Victoria" :P
ps: Learn to read Ryan Lowe of Roasedale Victoria, I don't want to get on the band wagon but just a friendly heads up that next time you want to buy something you read what your buying first. The advertisment was clearly for a High flow r32 gtr turbo. You can not claim that I sent you the wrong product when it was clearly marked high flowed to begin with.
http://www.skylinesaustralia.com/forums/topic/357902-r32-gtr/page__p__5720150#entry5720150
Becareful you don't accidentally buy a elephant next time your in the market for a puppy.....
Edited by Destero
https://www.sau.com.au/forums/topic/367999-tranf4m/page/4/#findComment-6033022
Hey all,
http://www.skylinesa...50#entry5720150
So lets get this straight. He has no turbo and no money?
https://www.sau.com.au/forums/topic/367999-tranf4m/page/4/#findComment-6033419
What is this, youtube? Just cos someone f**ks you over doesn't mean you should rip them off. Otherwise all the shit here applies to everyone who posted. Geez guys have a read of the forum guidelines. There aint no love in here...Some people aren't worth the time of day. Lets keep it like that. P.s the weather is shit.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/4/#findComment-6033881
bud you contacted me on my want to buy post
Hey all,
https://www.sau.com.au/forums/topic/367999-tranf4m/page/4/#findComment-6037392
sorry i dont fight with ethnic you get called a racist for that
dude give up, you fail at english.
everythings sent back, you got your funds back. Just drop it.
You're just going to keep getting attacked on this thread.
Maybe when they do the screen calls for the come back of "The Hillbillies" you could try, but other than that..
https://www.sau.com.au/forums/topic/367999-tranf4m/page/4/#findComment-6037406
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
