bud you contacted me on my want to buy post
Im guessing the reason you took so long to send the money and send the turbo back was your memory is bad... It all started with you so stop trying to make out it was my fault!!!
Sent 16 May 2011 - 07:04 PM
hey mate just wonering if youd sell the good turbo for $150 to victoria
The reason your getting flamed is quite simple... Your a idiot its not because you can't spell its because you are a scammer.
The whole thing was because you kept the turbo and would not respond in a reasonable time frame. If you think 4 months is reasonable IM sorry ill take back everything. You received my turbo which was in perfect working order that was taken off my skyline. You then said it would not fit because it was not standard, you then said your mechanic said it would not fit which to me sounds like both you don't know what you are talking about and when that failed you claimed there was a oil leak. All this time I did not argue with you even though the "not fitting" thing was a total load of bullshit, you then said it had a crack in the oil line and you were not happy with it. You received a refund within 5 hours with no complaining and with several apologies for the inconvenience in the mean time. You were the reason this went down the drain and ended up viral on the internet. Not because of me it was because of you I did everything on my end to ensure it went smoothly, If I sent it faulty do you really think I would agree and send the money back so quick?!?
In the end your reputation as a skyline owner has ended in tatters with no one on sau ever going to do business with you again and infact everyone here has actually got a bit of laughter out of it with your stupid non grammered comments. On receiving the turbo back its clear you did not look after it and in my professional opinion as a refrigeration mechanic who deals with welding, holes and abrasions on refrigeration piping the hole in the oil line was clearly created by bad handling probably from being tampered with in a attempt to keep it claiming it was faulty before realizing your dealings with me have ended up on the internet.
At the end of the day you have lost and I can guarantee karma will get the better of you in one way or another for the way you have treated me.
Thank you for wasting my and everyone elses time and i thank everyone on sau for your ongoing support. RYAN LOWE if you do continue to dig yourself a hole i am more then happy to provide chat logs and pics from both sau and my phone for you to use as a shovel.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6037582
  • Replies 98
Are you even sure its YOUR turbo he sent back to you? Wouldn't be surprised with this douchelord if he still has your turbo and sent you back his dodgy one.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6037597
I said a hip, hop a hippy a hippy to the hip hip hop you dont stop a rockin to the bang bang boogy said up jump the boogy to the riddim of the boogity beat.
loookseei eyes kan tork lyke tranzgender tu
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6037749
couldnt give to f**ks what ya do.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6040959
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
