Hey guys, before you blow me down, i have searched, like lots, but cannot find if the Z32 afm's fit up to the stock r32 gtr airbox, all posts say say they use pod filters....
so basically, want to hear from you guys with the stock air box in place as i'm keen to keep my engine looking stock.
anyone know if the z32 will bolt up to the airbox, also there seems to be quite some argument whether the z32 will fit into the stock pipework with some stretching, or am i looking to make new pipework.
all else failing i will go for the nismo units, which i know are great, but are also damn expensive........
cheers guys
https://www.sau.com.au/forums/topic/368025-z32-afms-direct-fit/
No they wont
Z32 has 80mm shell
Oem rb26 has 65mm shell
Nismo for direct replacement
Carry on
Yes they will
Z32 has 80mm outter diameter
Oem pipe is 65mm inner diameter, but will stretch
Nismo direct replacement is the easier option, but a z32 will fit and can look factory.
Yes they will
Ohh really??
Yes the rubber piping will stretch, but it does not bolt on to a stock BNR32 airbox
no, the Z32 afm's will not bolt on to the stock airbox. the spacing of the 4 holes on the end of the AFm that bolts to the airbox is different. you may be able to make them fit by drilling new holes in the airbox and using bolts to hold it.
far better option is just buy the nismo afms. they are not that expensive. about the same price as GENUINE Z32 afms if not a bit cheaper. the nismo ones will fit perfectly to your stock airbox and stock intake piping.
looking at your pic, the bolt pattern to the air box is the same then????
Bolt patterns are different but as you can see it can be made to not only fit but also look factory. Nismo is without a doubt the easiest and best option, but is NOT the only option.
I'm going to be straight out honest mate - I'd get a brand new one. I have purchased AFMs in the past that have worked but been f**ked the whole time and caused tuning issues for a long time.
For example - I could never set my Nismo injectors at the proper settings. Never knew why, car was always just a little weird even though it ran fine. CHanged the AFM, and problem solved.
Modded 2 stock 32GTR airboxes now for Z32 AFMs. You have to redrill holes and use 8bolts and nuts, as well as silicone to seal AFM's and nuts. Also check the alignment for the plugs and other piping that surrounds the AFM's in the engine bay.
Best of all, looks factory.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
