ok i am looking to upgrade from my stock turbo to a nice new one in a month or so.
engine is an rb25det with big front mount and 3 inche exhaust form turbo.
i wil be upgrading the fuel system at the same time so no need to mention it :D
what would be the best bolt on turbo or a turbo that wouldnt need too much work to put on? im lookin in the 1.5-2k mark
thanx guys
https://www.sau.com.au/forums/topic/36803-bolt-on-turbos/
Guest Robo's
If your looking at a direct bolt on, the HKS 2530,2535,2540 will pop straight on with no mods.
Im looking at this upgrade soon, but want something a little more bigger, say 3037 s pro, but i beleive you need a spacer and some line modifications. Still a spacer wouldnt be too hard to fabricate
https://www.sau.com.au/forums/topic/36803-bolt-on-turbos/#findComment-734586
I was just about to post the same question:
I've just purchased a LINK ECU and a Bosch 910 fuel pump for my R33 RB25det
Other mods: HKS GT FMIC,Exhaust, pod with CAI and Heat shield.
I thought what the heck, I'd save up a bit longer and get a new turbo and put everything on at one go. (It costs RM1k to retune).
What would be the best option for a turbo upgrade at the cheapest price?
I would like to get 230-250rwkw AND reliability for a car that will never see the track nor any street racing.
Thanks
https://www.sau.com.au/forums/topic/36803-bolt-on-turbos/#findComment-735987
I have an r33 gtst with a 3037pros turbo bolted to my standard manifold. It needs a spacer plate about 10mm thick to clear the side of the engine block, also you need new water and oil lines. l installed the turbo myself and it wasn't that difficult. On Race Paces dyno on 14 pound in conjunction with a power FC walbro fuel pump 740cc injectors, fuel pressure regultater, Z32 AFM, FMIC and full 3 inch exhaust it made 256RWKW.
https://www.sau.com.au/forums/topic/36803-bolt-on-turbos/#findComment-736484
