if you have a multi meter or even test lights, try and probe each of the possible wires (shouldnt be too hard to figure out the possiblities)
if you have enough of it and want to take it to a shop, try power international in mitchell
the wire for your starter motor is a big fat white with a black trace coming off your key barrel. (Or possibly black with a white trace) Its been a while so my memory is shit house.... just probe it with your test light and turn the key to start. You have to take the bottom part of the steering surround off to get to it. There are possibly other areas where you can get to the wire that will make it a shitload harder for a theif to get to, but this would be the easy way of doing it. You could use a relay and set it up, so that it takes a theif time to find it, and hide it in the engine bay somewhere. But then if he knows what he is doing he can start the car anyway. Slow down tactics are as good as it will get, Tow trucks can override any alarm.
I would immobilise the fuel pump, because if you start playing with the ECU and use your test light, there is a possibility you can blow it up.. You will need to probe for the wires though, cause I haven't touched them myself, so I don't know.
And the door sensor, is it an actual sensor?(I dont install alarms) Or does it just sense the power from the interior light switch? If its the latter I would try and get my hands on a wiring diagram, then you would be able to source power from a central point with the switches combine to turn on the light.
Sumo
P.S. im only a 1st year.... dont listen to me - No one else does :rofl: lol
Stirlo
I did this myself as well (saving a bucket load of cash) and I had to trace the wires for about an hour. I'm still trying to get the central locking to work, but seeing as it only has an actuator on the passanger door - I can't see it working in the short term until I purchase one for the drivers door....
Did you manage to get around this? PM me and I'll run through the wires I used.
DAN00H
DANOOH.. thanks I'll take you up on that, and hey did you end up getting your side intrusion bars installed? if so where?
its funny that only your passenger door has on, mine is the other way only my driver door has one, they donr cost much any way one about $30 from strathfield..
