im sure they have been used before. If you are going to use it make sure you check clearance issues and make sure all the surfaces are machined flat. For me personaly there are to many gaskets need in the same area which may cause leakages.
I have a similar one but mine has some angle.
Was gonna use it in the 33 with a td06SL2 but ended up going a T67 with a 6boost instead.
test fit on a rusty rb20 :)
sidemount.jpg?t=1308293562
IMG_0178.jpg?t=1308293736
the T67 is massive but i did try and mount it with this thing for interests sake, its pretty tight but i reckon if you moved the A/C lines and modified the engine mount it may be possible.
not using this so if somebody wants to buy let me know!
these flow horribly, having the w/g port @ 90* angle from the flow is pretty poor for flow and boost control.
Good for practicality, but If it was me I would spend the extra coin and get a port welded into the rear housing, looks neater too IMO.
yeh i had a similar adapter, had it on my high mount rb30 maniflod, it flowed well but as said clearence was a issue lol,
it was touching my bonnet, even flat spotted my housing hahahah.
if i had to do it again i would modify my manifold.
Yeh Sam and I tried something similar (from scratch) to well and truely hide my external gate.... we waited weeks for the thick metal to come in... then it had to be machined.... was absolutely wrapped... then I did a trial fit....
Unfortunetly, because my car has the same chassis rails as a gtr, it would never fit as they are higher then normal gtst's and as such less room... so you really have to be careful about clearance.
post-36975-0-00912600-1308483395_thumb.jpg post-36975-0-77215800-1308483396_thumb.jpg post-36975-0-24928800-1308483398_thumb.jpg post-36975-0-40312200-1308483399_thumb.jpg
^^yeah thats what i was worried about does seem a nasty angle to have it on......
but I really do wonder if having it on the housing would be any better..
I was worried too... have heard both good and bad... but so far has been fine, as has boost control. I did get it heat coated just incase.
I was actually trying to keep it hidden under the heatsheild, but that doesnt look too bad at all.
But really most aftermarket high mount manifolds have the gate pipe coming off at close to a 90 degree angle... 6 boost, trust etc
you will find the steam pipe ones are setup with less than a 90 degree angle as they have serious boost issues if its not.
hidden under heatshield you say?
This was when I was test fitting to make another hole for a bolt.
Great thing is it actually works as a really good heatshield because of where the gate is, I was getting a ton of heatsoak on the intake pipe - it was soo hot after drives I couldn't touch it... and it's meant to be as cool as possible... now its pretty much outside air temp, until I stop and the heat begins to sit and go up, but its generally much much cooler... did alot more then heatcoating....
with all the intake pipes on top you cannot see a thing under there.
post-36975-0-59673200-1308525883_thumb.jpg post-36975-0-17705500-1308525895_thumb.jpg post-36975-0-56803400-1308525931_thumb.jpg post-36975-0-06967300-1308525939_thumb.jpg post-36975-0-53408200-1308525947_thumb.jpg
    • Nah, you failed to pay your washer cover subscription and BMW have revoked your access.
    • Haha thanks Lith,  So it's currently working quite well and the torque reduction is setup and working phenomenal. It also got a custom torque convertor from All Fast in WA. Stall speed somewhere around 5500rpm unlocked but still with the lockup. The car went back onto the dyno after a 3yr hiatus (even with the dbw, and other mods completed in this time) managed to make ~515kw at all 4 hubs. Sean setup the Torque reduction which now sounds awesome and working well. We setup adjustable torque controlled launch control aswell.  Man what a feature. Especially when drag racing on street tyres I Managed to get out to the drags late last year and tick a huge bucket list item off of running mine and the cars first 9. Car went a 9.98 @142 Still had the young fellas car seat in the back aswell.  This was on 255/40/17 Nankang AR-1.  Currently the Turbolamik is still completing it's own torque calcs and managing shift times from there. Unfortunately emtrons can export is still a little restrictive to export the ecu calculated torque just yet but I have recently been suggested a work around that I just haven't had a chance to trial yet.
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
