Posted this up a few days ago in Tutorials/DIY but it seems no mods are around there, so I'll put it in here for now...
Ok, so the R34 GTR is now getting on a bit in terms of age and one of the things that doesn't last the test of time and the elements is the LCD screen on the multi-function display (MFD).
This was the case with mine - as you can see in the pictures below it was all cracked around the edges and was really annoying me.
So I started looking into what the reason for the cracking was and what options I had to fix it. After doing some forum research I found out that the problem is the polarising film on the front of the LCD cracks (due to heat/uv whatever) and this is what ruins the screen. There are 2 options -
1) Replace the screen with a brand new one - ~$200? (if you can find the right screen)
2) Attempt to replace the polarising film ~$20
I decided I'd have a crack at replacing the polarising film and after doing it I'd highly recommend if you have the same problem as me, follow my tutorial and do it yourself. Its just as much effort to replace the whole screen and is a whole lot more expensive. Even if you do have a go at replacing the film and you ruin your screen you aren't any worse of than you were before and you can replace the whole screen.
Before you begin you're going to need a sheet of the LCD polarising film. I bought the stuff from this place - http://www.3dlens.co...cdpolarizer.php and bought a 17inch piece and just cut it to size (which was good because I stuffed it up the first time and I had heaps left over to have another go). This is the film -
The other thing you will need for this job (apart from tools) is double sided tape - not the thick mounting stuff, the stuff that is just thin film between protective paper.
Ok, so once you have your supplies, you need to remove the MFD from the car.
Start off by pulling out your ashtray and unscrewing the one screw behind it. You should then be able to unclasp your gear stick boot and pull the whole plastic surround out. You will need to unclip the cigarette lighter.
Next, pull out the center air vent. Do this by carefully wedging a thin flat head screwdriver down the left hand side of the vent, and popping it out. I found using two works best - wedge one at the top and then use a second at the bottom and it will pop out. Unclip your hazard lights switch and pull it out.
Once you have the center vent out the plastic surround for the MFD will lift out of the way revealing the 4 hex head screws you will need to undo. Because they are near the winscreen you will probably need a stubby screwdriver, or, if they are as tight as the ones in my car were, and ratchet, socket and short extension.
Next, undo the 2 or 3 plugs on the back of the mfd - the brown and white ones need to have the little tab in the middle of the plug pushed down to pull them out. Levering them out carefully with a flat bladed screwdriver is the way to go.
Once undone, you can pull the whole unit out and move to somewhere more comfortable.
From memory, i think there's 4 more screws you now need to undo to open up the unit. See all that stuff in there - that's why your home-made mfd never worked!
Ok, so you'll need to pull the ribbon out (by lifting the plastic clasp up) and also pull out the plug the blue wires are connected to. This will seperate the screen cradle from the rest of the unit.
Next, remove the screen from the cradle. Again the screws were super tight (I managed to destroy the head of one of them and had to cut a new groove with a hacksaw to get it out) so make sure you have a good quality, appropriately sized screwdriver to get them out.
Once out, you will need to remove the rigid plastic piece that is glued/taped onto the screen. Carefully run a knife around the edge making sure not to push the blade in too far.
Once the plastic piece is off the cracked polarising film is revealed. Clean the remaining sludge off the metal frame with the knife.
Next, CAREFULLY, use the blade of a knife to lift the corner of the cracked adhesive film off the screen. It's stuck down pretty good and is quite hard to get it started so be patient. If you're not careful you will damage the actual screen itself like I did - if you only take a notch out of the corner it doesn't matter too much as you won't even be able to see it once you put it all back together.
Now I thought I'd go check I had the right film and that I hadn't damaged my screen up until this point, so I went and plugged it back into the car -
hmm.. so the polarising film is obviously important...
... and putting it the wrong way round won't help (don't worry it can only go on sticky side down)
that's it...
Ok, so with a sharp stanley knife cut your film to exactly the right size, peel off the protective film on the sticky side, and stick it down. I did this bit twice cos I ended up with a bubble the first time so I recommend sticking one edge down with the film bent and gradually laying it down onto the screen. If you screw it up you should be able to peel it back off carefully, cut a new piece of film and try again. Once on, peel the coating off the front of the film, line the metal frame with some new double sided tape and stick down the thick plastic piece: *make sure you put it back on the right way with the matt finish to the outside*
Put the whole thing back together again, unless yours is like mine and has fallen to bits as you pulled it apart. The plastic is really brittle and breaks very easily - araldite it all back together and nobody will over know.
Install it all back in the car whilst trying to beat my time of around 6 minutes to put the screen, screws and all the trim back in. Check out your good-as-new screen and post up your before and after photos in this thread :)
  • Like 1
subscribed
mine don't have this issue... but it is a 2000 model car so just a matter of time
by the way, what year is your car... i know that the screen went from sharp one to Toshiba in mid 2000 model and onwards
but not sure exactly when... mine is Feb 2000 model
  • 3 weeks later...
Umm, I think it was just the standard one, but you could use either on that page. I'd imagine the anit-glare just has a matt finish but the front plastic element on the screen has that anyway.
My screen which is also a Sharp only has a white screen appearing and nothing else. Pulled it apart and one of the ribbon cables were a little burnt on the connector, not sure how this is happening. Looking for a replacement cable but hard to find, not sure if the cable is the issue or the actual screen.
Any ideas???
Hmm check none of the pins are bent causing a short circuit/burning but I'd say something is fried. I'm pretty sure the ribbon cable should be pretty simple to get but it sounds like you might need a whole new screen
Thanks Chris for taking the time to put the pictures up, just ordered the film but was wondering what the double sided tape looks like/is called and where did you buy it from.
Thanks Ian
double sided tape was just standard bunnings issue stuff... make sure you don't get 'mounting' type which is a foam type.
As for replacement screens - not sure what modern equivalents are around but if you can't find anything here yahoo japan might be worth looking at.
  • 11 months later...
Have had this saved as a link for quite some time. Will definately need it one day.
Fantastic tutorial with all the detail thats required, thanks for taking the time to do it.
If I may ask, how is the quality of the replacement film?
Does it have the same matt finish as the stock one, or is it glossy? Also is the screen just as clear with the replacement?
Thanks.
No probs for the tutorial - I figure it will get more and more popular over time.
Yep, the matte finish is actually created by the plastic cover, not the film itself - Just make sure you put it back on the same way as it came off (as I mention above)
  • 3 weeks later...
http://i23.photobuck...MG_40314web.jpg
How do you get that to show all about the car, can you have that open on any LCD type or does it need to be a specific type?
The V-spec and V-Spec ii had more sensors around the car and thus the MFD showed more. If you have a 99 Model car you just get the basic ones. Your other option is to upgrade to the NISMO MFD software and you get the sensor with it to show everything.
(Plz correct me if I'm wrong anyone)
  • 5 weeks later...
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
