Did this today and very happy with the result.
The hardest bit for me was cutting the film and getting it to sit on there flat with no bubbles - etc. Got it pretty much spot on 4th time around.
Noticed that it is a necessity to cut it the new film to cover the LCD screen only, not the whole screen and the metal border like the pic in the original post.
Thanks again mate, great write up.
  • Like 1
  • 3 weeks later...
Hard to tell from that picture, wouldnt know until you get it out and give it a go.
Worst comes to worst, when you pull it out if you cant fix it - atleast it will be ready to have a new screen put in.
im not sure about that one but the guy that owned my GTR b4 me has replaced the plastic screen that goes over the film and has cracked the plastic around the buttons, thing rattles when driving and im going crazy because of it, also the screen looks like its been pushed on to tight like the plastic is pressing on the LCD screen in the corners (like when u put ur finger on a TV or computer screen) so i think he has done something wrong there to, looks like im gona have to pull it all apart and get my superglue/plastic weild out or buy a new unit because of this crack :verymad:
You can see it rly well in this pic buy what i mean.
Edited by T4NK
  • 3 months later...
I was able to get another shot of the MFD.
To me it looks like it could be the polarising film?
Can anyone confrim from experience?
Yeah, mine was like that but not as bad. A polarising film will fix it.
  • 3 months later...
ok so mine was a bit more tricky... took me 5hr 30min. I KNOW!
so they sent me the polarized film but the sticky side was on the wrong side so when I put it back together and wired it up all I got was bright pink and yellow I was pissed.
took me forever to find the problem thought it was the tape wire connection not in properly so it gave off funny colours.... but no it was the film so watch out guys the sticky side isn't always right.
anywho here are some before and afters and im glad I did it makes it look a million bucks :D
BTW to fix the issue of the film being around the wrong way I just stuck it to the plastic protector so in theory I just stuck it backwards if you get what I mean ;)
  • 3 weeks later...
This is great news. Was thinking about biting the bullet for a new screen, and now I just ordered the new LCD film instead!
Just wanted to add that you don't have to remove the ashtray and center console panel. You just need to pry off the air con vent below the MFD to expose the two screws. Don't forget to wrap your prying tool or screwdriver with electrical tape as not to scratch up the panels.
This video shows what I just explained and also how to further disassemble the MFD unit:
Also, for those of you still looking for a Sharp LCD screen, JDMautolink.com has them for sale. I am not affiliated with JDMautolink nor have I purchased from them before, but other than getting it from a guy on Yahoo Auctions JP, this seemed like the best option. If your MFD measures "kg/cm2", you need a Sharp screen. If it measures "kPa", you need a Toshiba screen.
Edited by javver
I noticed you don't have exhaust and intake temp? I'm guessing you don't have the sensors?
If you want the exh and int temp just for the looks, you can hook those two wires up to your climate control's amb temp, then go into diagnostic mode on MFD to pick up the exh and int temps :)
OK, so I finally got the job done. The hardest or perhaps most time consuming part was scraping off the glue between the original film and the screen. That part itself took about three hours. The rest was a breeze. Attached is a photo of my results. Turns out I'll be needing a new screen anyways if I want it to look perfect.
...or did I do something wrong? The flim is facing the correct side. I tried the other side, and the whole screen is white.
There's only one sticky side on the film.... What was the screen like before you replaced the film?
Also, I'd double check the ribbon cable on and from the screen, making sure you have reinserted it properly.
Hmmm did you get polarised LCD film or just LCD film?.
What he said^ check the ribbon able, and if still didnt work, check the screen protected is on the plastic bit that goes back over the screen as it makes a difference to the colour aswell.. If all that fails ask Jesus. ;)
Btw. The polarised film they sent me had the sticky side on the wrong way so make sure it is on the right way... I know the sticky side is only on one side but check to make sure as mine wasnt :) hope this helps
  • 2 months later...
hi, have had this bookmarked for a while. been meaning to give it ago, but im not sure if it would work for mine. just wondering if anybody could tell me weather my screen needs to be replaced, or if i can just go about this film replacement. mine has the big orange patch, i can see the unit working around the edges. and help would be great, before i go and waste my time on this if its not going to help :)
thanks mate, email sent
here are you photos I had to chop them down abit as they were huge photos and couldn't upload them as 2mb limit....
id say order the lcd plastic give it a go and then if the screen is stuffed well then you already have it apart ready to put a new one in.... but I think the new lcd plastic will fix it.... worth a try as it is only 20$
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
