got my screen a few days back. looks like they sold me a dud. the polarizing film is missing. so I have the same issue I did previously..
  • 1 month later...
cheers for the link btw, would have never thought alibaba.com. this is the actual product/seller i chose.
http://www.aliexpress.com/item/Brand-new-SHARP-SCREEN-LQ6BW506-LCD-MODULES-FOR-SUBARU-CAR-DVD-AUDIO-SYSTEMS-DISPLAY/1258839026.html
I got to this thread due to the polarizer issue at my own MFD screen. I checked out the link above and to me, this screen looks different to the one showed in the first post. Of course it's just the screen itself without the adapting electronics behind, but the screen looks a bit recessed compared to the MFD one.
Or is the pic in the link just an example pic?
No that is the screen. Pay a bit more for it though as I got burnt on the cheap one. Yes it was a new screen but the polariser was missing.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
