INCUBUS @ Rod Laver Arena
By sausagepianist · Posted
All good mate I'm mostly leaning towards the CANBUS differences being the problem. My arduino adapter is en route so I will report back. -
I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
