I have an r32 gtr doing a bit of hill climb with it. I have a brand new set of kumho ku36s on it and it does nothing but understeer. Just wondering everyones thoughts and help. Obviously i will in time be getting a set of r spec tyres but wondering if there is anything i could do in the mean time be it sway bars or what ever. i do have different sway bars all round. Any help or info would be great
https://www.sau.com.au/forums/topic/368184-r32-gtr-under-steer/
There is a whole binch of things that can induce and/or reduce understeer.
Try inflating the front tyres about 2-4psi above the rears.
I have a GTS4, and found that a heavy rear bar, combined with the standard front bar, was good for a neutral to slightly oversteering car.
Do you have any -ve camber in the front? Try taking some -ve camber out of the rear.
What spring rates are you running?
Also, try adjusting driving style. If you are braking as you turn in, then the car is more likely to understeer as weight transfers to the front outside tyre.
Also, checkout your front to rear ride height. 5-10mm difference can make quite a difference to how the car handles into corners.
+1 you want the wheel centerline to guard measurement to be 10mm higher at the front. Most people recommend 350mm front 340mm rear. I used to have 335mm at the front and raising to 350 made the suspension work a lot better. One you've got the ride height about right you should get it corner weighted and aligned. IIRC i'm using about 2deg negative camber at the front and 1.25 negative at the rear. Make sure you dont have any toe in at the front, or at least less than you have at the back. I'm using zero toe at the front and haven't had tramlining with either Falken rt-615s or Federal 595RS, which are similar styles of tyre to your Kumhos.
You WILL need a stiffer rear sway bar - makes a huge difference, and if you get an adjustable its easy to play with the under/over-steer balance.
EDIT: oh i see you have sway bars already - your front one may be too heavy, which will make understeer worse.
Changing the tyres is a waste of time until you get the front/rear balance right, and to make R specs work properly you need more aggressive alignment settings, which will mean more tyre wear for road use.
Five questions:
So you have four tyres the same?
What sway bars have you got?
What alignment settings do you have?
What diffs are in the car?
Generally to reduce understeer you will need more rear roll stiffness & less front. Which you can do with springs/sway bars/ride heights. Also the way you drive it makes a huge difference. On the other hand changing four tyres for a different compound shouldnt change the balance much if at all.
Lastly check that the drop links to the sway bars are done up properly. A loose rear bar will give you massive undertsteer...
Fender braces make a world of difference too.
To what? I mean, other than your bank account.
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
