I have an r32 gtr doing a bit of hill climb with it. I have a brand new set of kumho ku36s on it and it does nothing but understeer. Just wondering everyones thoughts and help. Obviously i will in time be getting a set of r spec tyres but wondering if there is anything i could do in the mean time be it sway bars or what ever. i do have different sway bars all round. Any help or info would be great
https://www.sau.com.au/forums/topic/368184-r32-gtr-under-steer/
There is a whole binch of things that can induce and/or reduce understeer.
Try inflating the front tyres about 2-4psi above the rears.
I have a GTS4, and found that a heavy rear bar, combined with the standard front bar, was good for a neutral to slightly oversteering car.
Do you have any -ve camber in the front? Try taking some -ve camber out of the rear.
What spring rates are you running?
Also, try adjusting driving style. If you are braking as you turn in, then the car is more likely to understeer as weight transfers to the front outside tyre.
Also, checkout your front to rear ride height. 5-10mm difference can make quite a difference to how the car handles into corners.
+1 you want the wheel centerline to guard measurement to be 10mm higher at the front. Most people recommend 350mm front 340mm rear. I used to have 335mm at the front and raising to 350 made the suspension work a lot better. One you've got the ride height about right you should get it corner weighted and aligned. IIRC i'm using about 2deg negative camber at the front and 1.25 negative at the rear. Make sure you dont have any toe in at the front, or at least less than you have at the back. I'm using zero toe at the front and haven't had tramlining with either Falken rt-615s or Federal 595RS, which are similar styles of tyre to your Kumhos.
You WILL need a stiffer rear sway bar - makes a huge difference, and if you get an adjustable its easy to play with the under/over-steer balance.
EDIT: oh i see you have sway bars already - your front one may be too heavy, which will make understeer worse.
Changing the tyres is a waste of time until you get the front/rear balance right, and to make R specs work properly you need more aggressive alignment settings, which will mean more tyre wear for road use.
Five questions:
So you have four tyres the same?
What sway bars have you got?
What alignment settings do you have?
What diffs are in the car?
Generally to reduce understeer you will need more rear roll stiffness & less front. Which you can do with springs/sway bars/ride heights. Also the way you drive it makes a huge difference. On the other hand changing four tyres for a different compound shouldnt change the balance much if at all.
Lastly check that the drop links to the sway bars are done up properly. A loose rear bar will give you massive undertsteer...
Fender braces make a world of difference too.
To what? I mean, other than your bank account.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
