Hi guys,
I took some quick photos today, so I thought I'd post them up here.
I know the car is filthy, but I was in a rush. General all black theme happening, might spray the rims black too.
Maserati style vents on the side, which I think look nice.
HKS Supercharger. Car sounds amazingly awesome. Just screams from the get go (even at low speeds).
Thanks,
Ali.
Edited by IOWNU
https://www.sau.com.au/forums/topic/368197-supercharged-skyline-some-pics/
Car came like that from Japan.
It is intercooled and also has an oil cooler I think, no overheating issues what so ever.
Yep running F-Con.
Have not dynoed it yet, will do that soon then post results here.
Hey I
Simply Freakin Awesome Man
I am slowly looking at add one for my 2005 V but I have an Auto and I will need an additional items to cool my Tranny.
Hey I
Where did you get it installed and Tuned and if the shop is in Sydney can you pm me a install price.
Where did you Purchase your HKS SC from, OZ, Japan, USA?
GL and you may think of getting a cover........
Yep running F-Con.
is it street registered?
Yeah just came back from compliance/registration last week.
Had to 'return the car back to stock' for compliance ;).
nice :thumbsup: . although the mazzer style front quarter panel vents do not appeal to me :P
Haha, they seem to be very polar, a love/hate thing.
  • 1 month later...
Yo any news on the dyno? im looking at getting this kit for my V. do you know if they have changed any of the internals on the car so you can run higher psi or if its just stock and running around 5psi like the kit says you should?
  • 3 weeks later...
Sorry for late update.
Had some ECU/starting issues that are now sorted.
The iternals have been upgraded so I will be running 8psi in the future, the car will be tuned again in 2 weeks after all work is completed.
Last week, the car was tuned at 4psi and made 254rwkw on a conservative tune (Impul ECU with HKS F-Con piggyback).
Also have new rims:
It is actually a semi-automatic.
It has cooler, oil cooler, cooling plates for transmission, bigger brakes etc.
Fuel pump ?
I dont mind the guards, i think would like awesome with tinded windows, different and blackedout grill also black lower grills and slightly tint the headlights bit darker.
Nice either way.
So its basicly just the stock HKS kit with some cooling and braking performance added, do you know if it has the HKS headders and cats also?
As for the lights i think these would look mint im going to get a set for my V
http://strafeautomotive.com/product.php?productid=16197&cat=266&page=1
Edited by T4NK
http://strafeautomot...&cat=266&page=1
They look good, but i think go for either LEDs or Halos, not both. I made a DIY in which u can do halos for like $40.
Im greedy ill take them both :D i think they will look mint on my my V, im smoking tail lights have my kenstyle front and rear fitted getting Greddy side as the Ken's didnt fit put them up front slam it on 20s gg btw soz for off topic :nyaanyaa:
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 馃槄
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
