Ok so i finally got around to doing a write up
this is so you can keep the tourque lock up clutch unlocked whilst in Manual mode.
you should notice abit better acceleration
transmission doesnt get so hot in Manual Mode
firstly this was scotts finding so thanks to him for sharing this :cheers:
things you'll need.
soldering iron and soldering wire
wire cutters
4ohm 10 watt resistor
small terminal spade(or similiar)
small bit of wire
first thing is to locate the trans ecu
its under this cover
you will need to remove the "hockey stick" strip cover on the door side of the foor.
and then remove this plastic nut under the glove box, behind the floor mat
You will see the trans ECU with a concuction of wires.
You will need to cnip the yellow wire in the above picture. its the second wire on the first row from the left.
the wire coming out of the ECU side will need to be soldered to one end of the resistor. the other end of the resistor will need to be soldered to abit of wire -> then to the terminal spade.
The spade will then need to be earthed.
Your Done.
If you want to wire a switch to this, you will need to get:
an on/on switch
and some wire(enough to where you want to run the switch)
Im sure you all know how to include a switch into the process. if not, i dont suggest you doing the mod yourself!
hope its effective,
Aaron
https://www.sau.com.au/forums/topic/368229-m35-trans-unlock-mod/
Thanks Aaron / Scott for the info.
I read in a misc post that when the g'box is modded , if left in drive, it will try to get into 5th sooner & could cause a slightly higher fuel consumption. If that's the case, it's a good reason to have a switch so you can return it to normal for dawdling around town, if that's your thing.
I also got the impression that the g'box would hold the chosen gear when driven in manual mode, ie more like a manual gearbox, but that sounds like the opposite of your comment that "you can keep the tourque lock up clutch unlocked whilst in Manual mode". Am I just misunderstanding?
Just so the expected result is more clear, can you explain what you experience (in laymans terms :)) with this resistor to earth mod?
Also, do you have the ECU pin number for the yellow wire?
Cheers, Leon,
Cheers, Leon,
it holds the gear abit better, which means simply putting your foot down wont change the gears in manual as it normally would. you would literally have to 'floor' it. dont know if thats got to do with the unlocked part but eh
this mode does kind of screw your fuel consumption, which was the original reason why i had the switch, but haven't used it since.
you'll get abit more acceleration as the clutch wont try locking up
i cant remember anything else..
i dont know which pin number it is, but its the torque lock signal or something. im sure scott will have the exam name and pinout
whats the red wire with the red clamp and orange wire coming out?
i dont know, i think it had something to do with the TV.. but it was like that when i got it.
I have no idea Craig. I could look it up sometime if you like. Mine doesnt have it. I hate scotch locks, whoever invented them is a knob. :spank:
Nice write up Aaron, I couldnt even find the time to drop the kick panel for a pic. :thumbsup:
Ok, so I could only find a 3.9ohm 10W resistor (Should work fine right?)
So after installing it, I can't notice any difference. Ex: 4th gear, foot down and it will still jump back to 2nd gear.... have I done something wrong or is it a very subtle difference?....or does the car need to be turned off when switching between the two? >_<
It will only make a noticable difference once your tuned mate, that 30kw I gained is because I'm at 285kw.
Now it's probably like adding a high flow filter. Just know your trans isn't heating up as much.
The resistor is only there to stop the AT light from appearing so I don't think .1 of an ohm is going to make a difference.
Could also take a while to notice perhaps
  • 11 months later...
I'm thinking of doing this mod as I hate the convertor clutch locking up when in D at speeds as low as 45-50kmph. I sometimes drive in manual 4 so it cant use 5th gear and the clutch lock up. I hate it as when I'm driving at 60kmph and the clutch is locked on its usually got the boost gauge at little to no vacuum or reading 0-2psi if I slightly push the accel pedal and the clutch dosent unlock. I also hate the clutch constantly locking/unlocking when i slighty move the accel pedal. I want to cruise at speeds up to 80kmph with more vacuum as this should result in better fuel usage. Then return the clutch lock to factory at speeds above 80kmph. When I first bought my 180sx it was auto and the clutch wouldn't lock below 80kmph when overdrive was switched on. This is how I want the M35 to be.
So how can I wire it as shown above with a resistor via a switch to keep it unlocked around the city then factory connection for highway? Can I use a on/off switch? My wiring knowledge isn't that great so any help is appreciated.
Cheers
Edited by slippylotion
  • 3 years later...
Hi all, first of all I don't want to upset anyone with what I'm about to say, I am just trying to ensure the correct info is available to all.
Talking with Mike from MV Automatics here in Adelaide he advised against this mod as it will just increase box wear and fuel consumption with no added benefit.
The M35 RE5R05A in manual mode will completely unlock the torque convertor at anything over 45% throttle input so the switch mod does nothing over 45% tps. An effect will be felt at low-part throttle only.
The ECU controls the transmission shift durations to the extent fitting a shift kit's effect is negated to a % due to the ecu trying to bring the shift duration back to target. This is most noticeable at part throttle when making anything over std power..the trans is prone to slip and groan. The Trans Go shift kit whilst does make a noticeable difference at higher throttle openings, the reason it is still smooth down low is the ECU bringing back the longer/smoother shift durations.
Personally I feel a boost controller mapped with tps on the x axis and boost on the y will most likely reduce M35 owners blowing up their transmissions as it would be able to restrict the torque levels at part throttle to the transmission ecu's controller shift duration zone. Another work around could be a TECU load input convertor to fool the ecu into thinking the tps is higher without effecting fuel and ign mapping in turn giving shorter duration shifts at lower throttle openings
He did recommend the thermistor and oil cooler mod and said there is no down side. He also mentioned if you want a better dyno figure to lockup the torque convertor, this will also reduce torque multiplication in the mid range however
I would like to hear if anyone has actually monitored the lockup clutch in manual mode to see if it does indeed lockup at full throttle as indicated in this thread. I'm going to check mine at the shop with the scope tonight.
Will report back to confirm or dismiss Mike's comments
Matt
Edited by BoostdR
  • Like 1
Testing tonight showed that mikes comments held true for normal driving mode but as pointed out on previously the torque converter does indeed try to lockup in manual mode from 2nd to 5th gear at any throttle opening position. First gear has no lockup.
I did note the lockup solenoid starts at 0.3amp and Ramps to 0.5amp Max.
I tried to stall the car up and confirmed the brake wire mod was giving 100% throttle opening.
The TCM however was still getting a brake signal.
5th gear comes active at 66 degrees trams oil temp and over.
My Gscan tool also showed a power switch setting which interests me, would be nice if this switches the TCM to different maps.
Matt
post-49288-14410133867762_thumb.jpgpost-49288-14410134020105_thumb.jpgpost-49288-14410134136496_thumb.jpgpost-49288-1441013421477_thumb.jpgpost-49288-14410134295366_thumb.jpg
Been running the torque converter with no lockup for 6 years now, I can't stand the way it locks up constantly in manual mode (nor can the trans). It's a pwm signal, not hard 12V, although that's what I used to throw at the solenoid on the dyno. Now I just leave it off.
Fuel economy, what's that?
Edit: Looks like Mike has a bit to learn with regards to the RE5. It isn't anything like the RE4.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
