I guess the idea is to give more direct response in manual mode without the cushion of the converter. I agree with a power increase without a corresponding trans reprogram lockup is a bad idea at high throttle openings. 6 years is a good soak test.
I called Mike yest twice to confirm his thoughts... Can't argue with hard data. I'll keep investigating this power switch
Well the same TCU is in the V35 which has a power switch, I can only assume they left it out in the Family wagon version. The switch input may still be there unused though...
I have the Jatco transmission service manual here, I should look to see if the pin is marked 'Power mode' :P
  • Like 1
Sounds like a plan Scotty, I'll have a look through the functions menu on the G-Scan and see if I can activate it via CAN command. From schematics it looks like the signal to activate 'Power' mode is transferred to the TCM by the CAN line which will make things harder to synthetically simulate(not impossible). If I can activate it I can easily log shift durations/manual change down rpm points/change points vs throttle position to prove how much the power map changes things to work out if further research is justified.
Matt
Edited by BoostdR
Well, looks like the power switch has nothing to do with the TCU, it must go to the ECU then down the CAN line, or perhaps just the ECU is doing all the adjustments directly. A lot of it would be throttle control and timing alterations anyway, for gear shifting.
Interesting reading of the consult 3 manual.
Clear Calibration data of the TCM (EEPROM Clear)
1. Shift selector to R(engine stopped ign ON)
2. Depress and hold brake pedal. Erase DTC while depressing accelerator pedal angle to 25-50%
3. Ignition switch to OFF (Hold for 10sec)
4. Ign sw to ON (10sec)
5. Ign sw to OFF(10Sec)
6. Ign sw to ON(10SEC)
7. Start
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
