i know i should be severly beaten for not knowing this but i'll ask anyway, im looking for a couple of turbos for a new project im looking at 2 t28 but someone sugested a skyline turbo. can someone tell me what kind of turbo the skylines run? and im guessing the gtrs are runing different 1s to teh gts t
lucas
https://www.sau.com.au/forums/topic/368255-skyline-turbo/
lucas
GTR's run with twin T28 Garrett turbos.
So you can say they are 'Skyline turbo(s)'.
https://www.sau.com.au/forums/topic/368255-skyline-turbo/#findComment-5873899
thats 1 sexy gtr skyline dam im jeleous
:laugh:
It's tuning house, Garage D's R32 GTR from UK.
Wish it was mine.
Mine looks similar but with white wheels and no spoiler.
Here are the R32 and R33 GTR Turbine Specs if that helps:
Compressor Housing: T3
Compressor Wheel: T3
Compressor Wheel (mm) 42.5 - 60.1
Compressor Trim: 50T
Compressor A/R: 0.42
Turbine Housing: T25
Turbine Wheel: T25
Turbine Wheel (mm): 41.5 - 50.5
Turbine Trim: 62T
Turbine A/R: 0.48
https://www.sau.com.au/forums/topic/368255-skyline-turbo/#findComment-5877279
unless it is only around 2.6L then the rb26 turbos will be WAY too small for a v12, unless you plan using 4 of them. you need to find turbos suited to the engine size you have. 2 rb25 turbos may possibly suit, but it depends on how high the engine revs.
https://www.sau.com.au/forums/topic/368255-skyline-turbo/#findComment-5879998
Two GT30 sized turbines at the least! Smaller than that and you'll get restrict the exhaust too much, then EGTs will be high too. You'll have to retard the ignition and so won't make much power especially at high rpms.
Twin gtx3071s *drool*
https://www.sau.com.au/forums/topic/368255-skyline-turbo/#findComment-5880074
bmw 5l, ive been on the bmw forums where this this is comon pratice and everyone say either t28s or gt3040 depending on what power i was looking for.someone did suggest quads hahahaha, not sure what vehical its going in yet something old problaly
Edited by jimbothepunk
https://www.sau.com.au/forums/topic/368255-skyline-turbo/#findComment-5881905
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
