Yeah I really need to have a chat to Chris about his brakes and what they were like. Might seem silly to some but I always said that if I was upgrading bits on my car I would fit top shelf stuff thats got proven results. That being said, I'm not made of money and the cost of an Alcon or AP set is pretty hard to justify when the china stuff seems to do ok....
Just rip the G4 sticker off and put a Brembro sticker on....problem solved :thumbsup:
  • Replies 45
Alcon or AP/Brembo ftw. JFK seems to do ok with CSC/Bmax brakes. D2/G4 is cheap, but hey whatever works and suits your budget. We are only talking about sprints/club level motorsport here.
Personally I buy expensive brand stuff because 1) I'm a brand whore 2) I can afford it. Each to their own I say. I may have somewhat expensive brakes, but they aren't over the top... and it doesn't mean shit if the rest of the car hasn't had appropriate money spent on the right areas too.
Are you going to review them on track as well?
Have a read here Ant:
http://www.skylinesaustralia.com/forums/topic/365787-k-sport-brake-review/
Read the whole thread - it'll take you a good 15-20mins, and Bris's response is very interesting to that other review.
Hence I'll do one for SAU and ensure it takes into account as much as i can, also comparing to a set of Alcon from Aaron @ Import Monster who is going to donate the workshop and stuff to help us out :)
I wont be able to a back to back @ track, given my current "brakes" resemble more of an angle grinder than anything else, so it wouldnt be reasoanble. I'll rely on Chris's input for that section given he's done that and then did a 1:19 with them on @ Sandown already.
End of the day if a D2/G4/Q234 kit offers for instance - 90% of the performance of an Alcon, well under half the price. I don't think there is a point of argument :D
Hey Ants, great read mate. Great to see it's back together and ready to rock. The rocker covers looks great and very autosalon!
Gday mate...looong time no hear! Thanks for the comments :cheers:
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
