Hey all, last weekend some tiprat smashed my stageas rear windsceen. Ive had the windscreen replaced and its all good now so thats not the issue, but i think some glass may have fallen down and maybe got caught in the door release or something and now i can't open the rear door.
Just wondering if anyone has any ideas how to fix it or a way to get the interior lining off the back?
Any help would be much appreciated, cheers.
https://www.sau.com.au/forums/topic/368277-rear-door-wont-open/
i remember when i had mine smashed i had to pull out all the rear trim to pull it out.
did u do it? or there place?
does auto close work? and does it feel locked ? ( eg. the handel is weighless) or does it feal like its being pressured?
Nah it was covered by insurance and it got changed while i was at work. Got no auto door and it is deffinately unloocking because you can feel the mechanism getting disengaged.
I think i might just need to clean the glass out but im not really sure what the actual problem is. I had the locksmith have a quick look at it today and he said it was trying to open but there was maybe something jammed in there and stopping the latch opening.
Edited by cal_cgg
Mine did the same, the handle had come off inside. I had to take the handle off from the outside, the trim and then unbolt the handle to get the lever. The trim is held on with 2 clips, u can get them off while its on the car, but it may break.
this may sound a bit silly, but lock the doors then try opening the rear as my central locking went out of sync once and the rear would open when the car was locked and not open when the car was unlocked, it sorted itself.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
