Hi Guys,
Can anyone recommed and post pics if possible of the size of spacers to use to fill the guards more on an R34 GTR using the stock wheels.
Would like to avoid tyre rubbing though. Im not interested in discussions around legal issues.
thanks
Jason
mine got 1 inch spaces on all 4
fill the guards well... i Think
looking to change on to RE30 or Silver LMGT4 in future
old photos from when i won the auction... but still the same deal in terms of Wheels
Dude, if that is indeed 1 inch (25mm) spacers all round - it looks perfect to me
thanks very much for replying
Jason
  • 3 weeks later...
Try just jap?
So a 20-25mm spacer would be perfect then.
If I did this I would probably see whether I could get spacers with the correct diameter center welded onto the wheels, then machined and painted.....
Those are Rays hubcentric 20mm spacers. Used to have a set before changing from stock wheels to te37's.
are they Hasemi fins or Nismo GT ones? (on the rear diffuser)
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
