I've recently bought a large pantech truck set up as a car transporter with tailgate loader etc etc.
The sides are corrugated aluminum which I rekon looks tacky.
So I want to redo the sides of the pan with flat alloy panels.
I've been told to use something called aluclad which sign writters use but thought I'd ask on here if anyone has any other products which are a light and give a nice appearance and easy to obtain
I'm not fussed about cost I don't mind spending good money as long as it's a decent product and will last.
I have considered plastics and colored Perspex it's heavy compared to even .6mm steel panels
Any advise or experience is appreciated
https://www.sau.com.au/forums/topic/368310-alloy-panneling/
Are you going to be using any internal frame supports Brad???
A couple of trucks I've seen have ended up looking terrible (you can see ripples all down the panels) as there wasn't enough support.
On our old boxed trailer/transporter we ended up using mdf walls with a .4mm steel panel over the top for easier signage etc and a cheaper alternative to probond.
https://www.sau.com.au/forums/topic/368310-alloy-panneling/#findComment-5879788
Yeah there is a steel frame around the truck now which has corrugated steel riveted to it.
I was considering unbolting the whole pan and fabricating a new alloy frame and using that instead. Mainly to try and keep the weight down.
Or just drill out the old panels and rivet on the new alloy stuff. Don't want to leave the old crap behind it.
I'll look at those products today thanks guys.
https://www.sau.com.au/forums/topic/368310-alloy-panneling/#findComment-5880414
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
