yo yo.
i am in need of the following-
ECU
Motor wiring harness
coilpack wiring harnes
inlet plenum
cam covers
if you have upgraded your bits and nolonger need your crappy standard stuff or wrecked the whale let me know. :thumbsup:
https://www.sau.com.au/forums/topic/368338-wtb-standard-s1-r33-bits/
34 stuff and S1 25 no compute
ok, bought some stuff today. just need coilpack harness and CAS.
i have acquired a 25 head. going to make the white car breathe better.
  • 3 weeks later...
  • 1 month later...
  • 7 months later...
