Ok so im changing my setup on my r33 series 1 and i have a whole bunch of performance parts that im not going 2 need and there just taking up space in my garage
Microtech lt12s with plug in adapter around $700
Big cc injctors with rail and adapter and malpassi fuel reg not sure on the cc think around 800cc with only about 3000km on them around $600
Exedy twin plate clutch practily brand new less than 500km on it cost me like 2500 around $1000
5speed manual with just under 80 000kms on it shifted perfect no noises or knocks $1300
eagle forged conrods with only 3000km run in ks $400
standard intake manifold $50
stainless steel top mount manifold with external wastgate unknown brand fitted but not plummed bak 2 exhaust manifold is warped and would require maching $100
standerd exhaust manifold $50
High energy sump $150
Blitz sbc dual solinoid boost controller $100
and various rb25det enging parts and acesseries
Im located in Keilor downs victoria 3038
if u have any question or need other random r33 parts and 4 prices feel free 2 call or message me(chris) 0432165542 my garage is like a wreckers at the moment and there is so many parts that have built up over time i havent even got room 4 my car so have 2 clear it out asap.Also if you wont pics of any parts txt me and ill send them 2 ya
Edited by chrisr33gtst
https://www.sau.com.au/forums/topic/368341-r33-gtst-performance-parts/
Exedy twin plate clutch practily brand new less than 500km on it cost me like 2500 around $1000 SOLD
5speed manual with just under 80 000kms on it shifted perfect no noises or knocks $1300 SOLD
standard intake manifold $50 SOLD
Blitz sbc dual solinoid boost controller $100 SOLD
High energy sump $150 SOLD
Hey mate of memory the microtech lt12s didnt need its own map sensor it uses the cars standed sensors .It dosent use the airflow meter so u can remove that and it comes
with the plug and play adapter for a skyline loom.So as simple as plug it in hook 1 manifold presure line then drive it to tuner
Microtech lt12s with plug in adapter around $700 SOLD
Big cc injctors with rail and adapter and malpassi fuel reg not sure on the cc think around 800cc with only about 3000km on them around $600 SOLD
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
