A couple of quick questions :)
1) Is the RB25DET (R33) Tomei head gasket OK to use on an R34 Neo engine?
2) Is is definitely OK to use a 87mm bore head gasket on a 86.5mm bore engine? I guess this will drop the compression ration slightly.
3) Does the Tomei head gasket come with a oil restrictor, and what size is it?
Thank you!!!!
https://www.sau.com.au/forums/topic/368361-tomei-head-gasket-questions/
1. Yes
2. Definitely ok
3. I have never ever seen a restrictor come with a gasket and I have bought dozens. But the Tomei Oil Gallery Orifice is 1.5mm as stated above. Refer to the forced induction section for restrictor sizing depending on application and pump being used
1. Yes
2. Definitely ok
1, I concur.
2. yes, doctor, I concur.
3. yet again, I concur. the restrictor orifice only comes in the tomei full gasket kits (ie the ones that come with MLS head gasket, exhaust gaskets, inlet gaskets etc. they include the oil feed restrictor. but if you just buy a head gasket on it's own, all you get is head gasket. need to buy a restrictor separately.
Thanks to everyone for the quick replies :)
I will source the restrictor separately.
1, I concur.
Arrgh one more question....
I presume the Tomei 1.5mm oil restrictors for the RB26DETT will also suit a RB25DET Neo??
Thanks :whistling:
I'm just asking a noob question but why do you need the restrictor? Is this due to the head gasket change or something else? I thought you change the restrictor if you upgrade oil pump to maintain same flow in oil around the engine... Also noticed many different thicknesses for headgaskets. Does increasing the headgasket size increase bore capacity by that little tiny bit thus requiring a tweak up of the tune?
I'm not nit picking, I genuinely don't know.
the oil feed restrictors are a good idea even with stock oil pumps. especially if your engine is going to see a lot of sustained high RPM use. as kiwi said even a stock oil pump running and long periods of high rpm will flood the head with oil.
as far as thicker head gaskets go they don't increase the bore diameter. they do slightly increase chamber volume which reduces squish and reduces compression ratio. you need to ensure you know what you're doing when chosing head gasket thickness so you get the characteristics you want.
I have actually just bought two Tomei 87mm bore 1.2mm thick RB26 head gaskets and both came with the Tomei 1.5m oil restrictor in the bag. Both head gaskets were bought about 6 months apart and came from two different vendors.
Edited by Ramius83
Damnit!!! I just bought the head gasket and the restrictors separately.... And wasted $21 in the process... Nooooooo!! :)
    • My first thought is run hardlines, but running a soft pipe is easier and quicker, though normally more exxy...
    • It sounds like the perfect time to do easier tasks like, work out how to pull the headlights fully apart, clean them inside and out, and make them meticulous... Or lose all the clips, f**k up polishing the lenses, and get frustrated with that job while you can't do bigger more fun ones and wind up with no usable headlights...   I mean... What?! 😛
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lipomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, more time to contemplate rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
