Hey guys,
I am new to these forums, and new to owning a skyline.
I got it just over a week ago, and it has an aftermarket headunit in it, which is a pioneer unit from japan. It has a CD and cassette to replace the double din. It also has 4 Pioneer 6.5s (2 door 2 back). When I put a CD in and turn it up to max volume, there is barely any sound coming out of the speakers, there IS sound, you can definitely hear it, it's just really low.
A mate suggested that the head unit could be the problem, what do you skyline enthusiasts think?
I plan on replacing the head unit this week, using the guides I have found here.
https://www.sau.com.au/forums/topic/368364-sound-system-volume-problem/
sounds dodgy for sure, maybe a grounded speaker .frame using up the power, amp section burned out on the deck. not upping the watts to the proper levels,
attenuation turned on
interior sound mic turned on, high noise = high volume, low noise = low volume some decks have that
does the fader work ?
i take it the fm radio is loud ? if so the deck has the sound EQ for the cd setup on I would suss. ? pioneer uses different eq and sound settings for cd and radio on some radios
wouldnt worry until you ditch the deck, then check the speakers "OHM" load. but if they have a capacitor or xover network you can see mixed numbers other then 4-8ohms
get a installer to do the work, or you might be in for more then you bargain for , a quick fix for a pro or days of ripping your hair out on the forums your choice ?
and welcome to the skyline world, and get a ADR approved alarm first /asap
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
