lol
I went from ~76kg to 108kg in around 3years at the gym, between ages 19-21
Then added 10 more the next year doing weights at home, but that would have been mainly "weight" & not muscle
Lol well that's it isn't it.. It takes a bloody long time to put on "pure muscle"
It's taken me nearly 5 years.. With a couple of Injuries ie broken hand to put on 17kg of muscle
Some people love talking up
if I can be bothered to find the article i'll post a link, but I have read that naturally it is nearly impossible to put on more then 5kg of pure muscle in a year.
was only one thing I read could be wrong but according to them and the studies they did on professional athletes 5kg is the max.
Until I see before and after DEXA scans, I don't trust anyone to know what they've put on.
Who cares about how much muscle mass you've put on anyway...more important is what you look like or how much you can lift. Chances are if you're bragging about how much muscle mass you've put on, you're likely not satisfied with appearance or strength.
Well he's trying to say its all muscle, don't know if he's on the gear or not... Anyone can eat for 7 weeks and put on a few kgs.. I refuse to believe its all muscle.
He was trying to impress some girls on FB lol wanker
Question this, you must not
  • 6 months later...
  • 4 weeks later...
Is that a serious question?
First off, I NEVER discuss stuff like that, even though he doesnt compete in a drug tested fed, its no ones business, including mine.
And secondly, why didnt you ask me if he smokes or drinks?
Bit of an over reaction. Fair enough that you don't ask but in a thread concerned with ideal physiques, the question about natural or not is relevant.
Cant argue that smoking and drinking have the same effect to someone's body that steroids and company have
Yeh it was a serious question. If you dont want to answer it thats fine, I wasnt suggesting he has or hasnt, it doesnt take anything away from what hes achieved in my opinion. The man clearly has a ridiculous work ethic regardless.
Why is there such a stigma attached to anything steroid related with some people?
I didnt ask if smokes or drinks because to be honest, thats not the first thing I thought about when I saw the photo of him.
it's probably like the IFBB bodybuilders - they're all obviously on the gear, but no one likes to acknowledge it. I've been told that testing/not testing is why there are different powerlifting federations as well? (feel free to correct me there).
Markos I know it's a touchy subject for you, but smoking and drinking only affect performance negatively rather than enhancing, so the analogy is not all that clear.
I've got nothing against people who use whatever to help (as even creatine supplementation is technically not 'natural'), only those who are using and pretend that they got where they are purely from training and eating.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
