Pic could be deceiving, but he looks somewhere between 90 and 95 in the pic. Not hating...he's got an awesome body (nohomo), but he still looks athletically muscular (what I prefer anyway) rather than a bodybuilder level of hypertrophy, which would be expected at that BF/height/weight from what I've seen. He's got slightly less body fat than me and weighs 22kg more at the same height...with another 22kg of muscle I reckon I'd be a fair bit bigger than that. Maybe he's got a beast set of legs? Haha
Yeh beast legs, shoulders and back. here's the 118kg pic. I think I need to stand next to him for comparison or something for you to realise size.
He used to be on here but not now (not this section though).
Edited by 10 4
  • 1 year later...
Thought I'd revive this thread with a picture of Steve Cook.
Been watching his videos on youtube. Find them to be pretty good, although not the full versions.
Anyway
cant find a decent shot of him outside of competition.
Show ready to normal every day is different. He gets down to 3% for shows but sits around 8% normal at around the 100kg mark
You may have actually seen him at the show. He was on the Optimum Nutrition stand
Edited by -FIGJAM-
Id be happy to be 100kg with 8%
I wonder if you could get to that physique naturally.
Apparently his stats are 95kg, 185cm. BF 5.8%
This puts his Fat free mass index to about 26-27. Research shows about 25 to be approaching the upper limit
Paid athelete and competes in the IFBB. Too hard too tell these days!
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
    • I promise there will be no chance of replacing the rad support....  It is barely twisted and it's way more likely to just be driven around with a slightly twisty support. As long as the headlight can be bolted in there then no harm no foul lol. The reo may need to be un-bent a little but truth be told if it all somewhat lines up and is hidden when the car is assembled the level of f**ks will be 0.0
    • this thread delivers, once again Skyline owners, our cars spend more time off the road than on the road
