lol, must be!! I can confirm he is in fact 2m tall.
awesome physique for the height - thats what you get by being in the SAS; got a family friend in the SAS and his body was transformed on a massive scale over the years of intense training.
on a personal note, my great-great-grandfather was awarded a Distinguished Conduct Medal for 'distinguished services under fire or under conditions equivalent to service in actual combat with the enemy'. He refused to carry a weapon and was therefore assigned stretcher duties. In the heat of battle he (mistakenly) picked up an injured enemy soldier, realized his mistake when the soldier protested, turned around and rushed him to the enemy camp...... a very inspiring story to my family :)
  • 1 month later...
  • 1 month later...
not very far off this... just not as lean haha
That's pretty decent, Id be happy with that. I think I am well on track for that at the moment. He's more ripped than built.
I'm a skinnier sort of build, so I don't think I posses the genetics to get built like some of the other pics in here unless I get on the juice...
Bullshit asshole, nobody likes the tuna round here.
Nothing can stop you from weighing 100kg if you really want to...the muscle gains will do it regardless of bone structure. However, due to bone structure, there's only so much width you can add before the muscle compounds and you just look bulky/tanked rather than big. As is the reason why short guys can look more tanked than than taller guys, despite similar strength.
more on Bruce
apparently he really directed body building to where it is today. Was one of the first to have shakes in between meals, mind you I believe he was blending whole meats and veggies in his shakes. He was meant to have worked out for hours on end every day of the week as well. Wanted a fully functional martial arts body with the emphasis on strength, speed and agility.
I don't do torrents and cbf searching, so you'll have to explain it to me. From the last time I read about him he was an influential figure in a lot of ways, no doubt, but didn't see anything about a link to the field of bodybuilding...
before him bodybuilding was alot about just being big. He comes along and all of a sudden it starts swaying about being cut as well.
he also is one of the first known people to use protein shakes as a supplement (however he was using raw meat and actual blended food rather then powders), also used electro therapy i believe to help gain.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
