I'm sure its perfectly do-able - there is a guy in Wellington replacing the RB30 in his Skyline with the Toyota engine - considers it stronger than the RB. But if I ever get an M35 (as well as my C34!) I would be keen to put a VH41 or ideally a 4wd VK56 setup in it.
BTW New Zealand's fastest 1/4 miler is 2JZ powered:
http://www.insane-racing.co.nz/home.html
https://www.sau.com.au/forums/topic/368395-m35-2jz/page/2/#findComment-5875601
  • Replies 70
AWD VK45 from a Cima stroked out to 5.6 would certainly be awesome and is on my "if I win Lotto" list :)
2J > RB
All Toyota needed in the 90's was the GTR's ATTESSA.
https://www.sau.com.au/forums/topic/368395-m35-2jz/page/2/#findComment-5875622
its nice to dream. but the cold hard facts are that the sheer cost involved in doing such a conversion, makes it completely pointless unless uve got shitloads of cash just lying around. for the money you would spend getting it to work, you could buy a seriously quick supra and prob have enough change to pay for an extension on ur garage to put it in. if you want a quick stag, work the vq. if you want a fast 2jz powered wagon buy the crown or buy a cheap commodore and put a 2jz in that. its been done before and it works well.
https://www.sau.com.au/forums/topic/368395-m35-2jz/page/2/#findComment-5878119
stick a 20B in a stagea i dare ya :P
waits for the flameage............ i'd do it just for shits and giggles if i had the coin!!!!!!!!!!!!!!!!!!! :D
Good motor...pity if you want to go up a hill though :P
https://www.sau.com.au/forums/topic/368395-m35-2jz/page/2/#findComment-5879633
20B in the Cosmo had the same 407nm as our VQ25det from factory.
Rotarys do have torque, they have HEAPS of torque, but Torque = power / (2*Pi*RPS). So any high power output engine has big torque figures to match, but they make torque at such stratospheric revs and lack ANY torque in the lower revs. So in a real world situation theres none available :thumbsup:
Anyway, sorry about the rant.
To me the idea of replacing a multi award winning, highly advanced platform like the VQ V6 with an out of date lump of iron would be a really bad decision from an engineering perspective. This decission could only be made on personal grounds, so you will need to forget any advice you get from anyone else. If you have a spare $10 grand and want nothing but a 2JZ powered M35 then do it, but don't ever ask anyone what they think about your ride. :thumbsup:
I know which one I'd rather have!
Edited by chad bob
https://www.sau.com.au/forums/topic/368395-m35-2jz/page/2/#findComment-5880882
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
