Guys, R33s have the battery in the boot, R32s have it in the engine bay.
moo_r32, You don't really have any other choice but to run the power wire from the engine bay to your boot. Keep it on the other side of the car as your RCAs to reduce interference. Make sure you fuse the power cable not more than 30cm from your battery terminal too.
33s and 34s have em in the boot but 32s have em in the engine bay
I moved mine to the boot in my 32 wasnt too hard just have to run a very large cable under the car from the bonnet to the boot
you can get kits which come with all the terminals, battery box and cable etc
if you dont want to move the battery the best place to run the cable is down the drivers side under the carpet dont run it under the plastic moulding run it along the floor
R34's have the battery in the engine bay too - well, mine is anyway....
  • 3 months later...
Yeah battery placement is weird, my SII R33 Sedan has the battery at the front drivers side of engine bay, and overflow bottle on the right hand side near air filter box. Im gonna have to run a power cable to my boot soon as well. Although with no battery in the boot that little shelf makes a nice spot to mount an amp and sub.
Running an earth back to the battery or to the chassi is 6 of one and half a dozen of the other. Easier to use the chassis but for mine I ran one from the battery. The biggest hassel is getting it past the engine bay firewall. Took me ages and a few attempts.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
