Hi guys. I had my dump pipe upgraded to 3" and they found a crack on my manifold. Does anyone have connections to a new one? Or is welding better for now? Not many stageas around my way. Any help would be appreciated. I heard stainless ones aren't that great. Is that true?
Where are you?
What kind of Stagea you got?
The more info you give the better the help you get :thumbsup:
*EDIT* My bad just read the rest of your thread title :whistling:
Edited by SatchiThaStagea
you can pick up a 2nd hand manifold for around 50 bucks. they wroth nothing, even if you opt for a low mount from ebay they around 200-300. better than a cracked one.
and the rest depends on how good you are at bolting the thing up.
from what i know any Rb20/25 exhaust manifold should fit.
Hey sorry mate ye it's 1996 stagea with the rb25det. Where are the $50 ones? And is that a stock one? I've looked on eBay but I'm not too sure on them. Are the stainless Ones k? I'd get my mechanic to install it. I haven't got time or tools to do it. I'm in Victoria.
Stainless manifolds (especially cheap ones) are more prone to cracking than the factory standard cast items, so unless you are trying to get every last kW out of your car I'd just try and source a standard one.
I recently cracked and replaced the manifold on my R33, it's a little fiddly but easy enough to do. Just be prepared to have snapped manifold studs drilled out :thumbsup:
Hey my stagea does choke up when I floor it. Abit of lag. Would the small crack be the cause?
Possibly, I picked up a little response when I replaced my manifold. I mean the more exhaust gasses leaking through the manifold, the less exhaust gasses that flow through the turbo to force more air in on the intake side.
That, and I imagine any exhaust gasses that are leaking before the O2 sensor would cause the ECU to not run as well as it possibly can
or if you want to do it a cheap way you can use a normal welder to just weld over that crack...... dont know how long that will hold since its steel weld on a cast iron manifold, but some people have done so and its been ok for years. (would advise against this though)
so i guess my estimate for 50 was a bit over the top eh??? seems like they exist cheaper
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
